Vertical Mount Heaphone Jack
Author Vertical Mount Heaphone Jack
thegrinch
Hi, I am looking for a vertical mount, stereo, 3.5mm headphone output jack that can be soldered to a pcb and mounted to the front panel. I am looking for a part that is the same height as the thonkicon mono 3.5mm jack, so that both can be used in the same pcb:
http://store.synthrotek.com/thonkiconn_mono_jack
Parts numbers and/or supplier links are appreciated. Thanks!
guest
this might work, but youd have to run a ground wire:
http://www.mouser.com/ds/2/222/STPX3501-334581.pdf
otherwise, find some stereo jacks you like, and use them in place of all your monos as well.
euromorcego
indeed, and since you use the synthrotek link for the mono jacks: http://store.synthrotek.com/1_8th_in_stereo_jack
fitzgreyve
Thonk now do them?
PJ301CM STEREO
https://www.thonk.co.uk/shop/3-5mm-jacks/
tabs/pins are wider than a thonkiconn though.
thegrinch
fitzgreyve wrote:
Thonk now do them?
PJ301CM STEREO
Thanks so much. This is exactly what I was looking for!
guest
theyre a little taller than their standard mono jacks, but pretty close to the pj301bm.
