Silent Way v2.7.0 released - adds Scala support
Author Silent Way v2.7.0 released - adds Scala support
Silent Way v2.7.0 is released (all platforms and plug-in formats).
Changes in this version:
* Added support for microtonal tunings via Scala files to SW Voice Controller.
* Added an ‘Any Note’ parameter to SW Trigger.
* VST3 versions now support all MIDI CCs (e.g. for SW Learner input, or for transmission as MIDI by SW ES-4 Controller).
* Fixed a problem where the UI would freeze when closing the plug-in window under macOS 10.13 “High Sierra”.
* Fixed the range of the ‘Input To Gates’ knobs in SW ES-5 Controller.
http://expert-sleepers.co.uk/downloads.html
electrik noize
woah, Scala support?!?!
w00t!!
Hardtex
Very well, will try it out this evening. Miley Cyrus
zoukouard
woah
ASYX
hello i am new here pls point me in the right direction
my issue is as follows
i am currently on mac ableton 9 and using vcv rack ( great fun altogether )
now with my ES 8 i expect to receive and send cv signals
in ableton i receive (audio) signals from the ES 8 but silent way doesn't show up ( i tried to install multiple times also 2.7 )
in VCV rack i can send cv and audio but i don't receive any signals from the ES 8 ?
so basically in ableton i have no cv tools
and vcv doesn't receive what a bummer ! anybody had and fixed similar issues
When installing Silent Way, did you also install the most recent iLok Licence Manager?
Is this a macOS permissions thing? Did you click yes when macOS asked you to allow VCV access to the microphone?
ASYX
thank you for the quick replies
for now i followed the advice to just use the demo mode and see if it works
is Ilok needed for the demo mode ? (i installed it but didn't know what to do with ilok at that point
Yes there was the question and unfortunately i denied access to the microphone as i thought that's the last thing i want to use, but there is this permission issue.
have to figure out how to get back there
ASYX
ok
under security and privacy settings i can go to the microphone and allow access for vcv
that did it
now only silent way needs to show up in ableton and i am a made man :-D
Have you tried both the VST and the AU?
