Reaktor blocks 2 modulation source limit
Author Reaktor blocks 2 modulation source limit
orbita
Is it just me or does the 2 input (A,B) modulation source limit in Reaktor blocks seem like a massive limitation?
hermbot
Depending on the module, yes.
Now, you can scale and invert those two inputs to any number of destinations within the block, but you are still limited to those two.
For most modules that are single-purpose blocks it's usually not a constraint.
But for beefier blocks like the DWG it would indeed be nice to add more.
Oldstench
That's what CV mixers are for.
big job head
https://www.native-instruments.com/forum/threads/tutorial-adding-modul ation-sources-to-blocks.318369/
you're welcome thumbs up
big job head
yes but sometimes you don't want to mix CVs, you want 4 different sources to 4 different destinations.
Oldstench
I realized that just as I hit post.
Howes
I really wish there was a simpler way of adding more modulation inputs without diving into core. Would be nice if this was changed in an update
BoBSwanS
Is this of any use to you lot??
https://www.native-instruments.com/en/reaktor-community/reaktor-user-l ibrary/entry/show/11419/
Exiannyc
I too was really frustrated, actually kind of offended, when NI developed such a limited modulation paradigm for Blocks. It's like being told you only get to color with 2 different crayons.
And I was really happy when Matthew Friedrichs and some other people started developing much richer ways of addressing this.
Simple Man looks like a gateway drug for Lyrebird, which is Matthew's utterly insane (paid) West Coast and beyond Reaktor block. Every knob on the front panel can have 8 modulation sources, all in differing mod depths. Seek it out.
