Any Attenuverters/Polarizers in frac ?
Acid Mitch
Post by Acid Mitch » Sun Mar 04, 2018 11:51 am
Modular grid and the mighty Google don’t seem much help on this.
Surely there must be attenuverters/polarizers in frac ?
What are you guys using ?
diophantine
Post by diophantine » Sun Mar 04, 2018 5:05 pm
There's no dedicated attenuverters that I'm aware of; they're all built into other signal processing modules.
Blacet Splitter/Buffer/Mixer does it, albeit only on one channel per each section, like the old Blacet Mixer and Splitter modules.
Personally, I use the recently discontinued Blacet Mixer/Processor, and the Bananalogue CP3.
I also have a couple of signal inverters built into my MiniWave expanders, which I can then feed to my attenuators.
Adam-V
Count Modula
Post by Adam-V » Mon Mar 05, 2018 3:54 am
I DIYed mine from Ken Stone mixer PCBs.
Adam-V
Acid Mitch
Post by Acid Mitch » Mon Mar 05, 2018 4:15 am
diophantine wrote:There's no dedicated attenuverters that I'm aware of; they're all built into other signal processing modules.
Well I guess that explains why modular grid didn’t come up with anything.
diophantine wrote: Personally, I use the recently discontinued Blacet Mixer/Processor,
I didn’t know the Mixer/ processor could invert stuff. I thought it just added offsets. Will have to get mine fixed.
Adam-V wrote:I DIYed mine from Ken Stone mixer PCBs.
Which ones ? There’s a few different Ken Stone mixers.
nikmis
my last name backwards
Post by nikmis » Mon Mar 05, 2018 7:05 am
I diyed two based on fonitroniks attenuverting mixer, just using perf board
http://www.modular.fonik.de/pdf/f-mixer-rev2.pdf
fracmonkey
JB or not JB, that is the question.
Post by fracmonkey » Mon Mar 05, 2018 8:41 am
Blacet should probably re-do the Mixer Processor in 1.5" module...although the SBM has two inverters: one on mixer, one on splitter. Also there is one on the Filthy Filtre.
Acid Mitch
Post by Acid Mitch » Mon Mar 05, 2018 9:14 am
nikmis wrote:I diyed two based on fonitroniks attenuverting mixer, just using perf board
I like the multifunctionality of them.
fracmonkey wrote:Blacet should probably re-do the Mixer Processor in 1.5" module.
Great idea!!
fracmonkey wrote: ..although the SBM has two inverters: one on mixer, one on splitter. Also there is one on the Filthy Filtre.
Aye, SBM is next on my shopping list. Looks quite handy.
diophantine
Post by diophantine » Mon Mar 26, 2018 6:08 pm
fracmonkey wrote:Blacet should probably re-do the Mixer Processor in 1.5" module...
Just want to say... if Blacet does this and keeps the LEDs, I hope they keep the separate red/green LEDs for red/green colorblind folks like myself!
The guy designing the UI for Mutable Instruments modules has been soliciting feedback from mutants like me (there's a thread in the Eurorack forum) and it reminded me just how awesome it is having those two separate LEDs on the Mixer/Processor.
Honestly, my only complaint about the Mixer/Processor is that I only have one of them....
Acid Mitch
Post by Acid Mitch » Tue Mar 27, 2018 12:22 pm
SBM and dual vca arrived yesterday. :party:
The SBM is great. I’m surprised a bigger deal isn’t made about it. Every Frac rack should have at least one.
Synthnerd
Post by Synthnerd » Sat Apr 28, 2018 6:34 pm
The MX2040 was one of the very first Blacet kits I built so many years ago. Something interesting I noted about the two separate LEDs is that on two occasions, after rearranging modules, one of the mixer processor LEDs would stay lit up and nothing worked. I found in both cases that I accidentally plugged the power cable in offset one pin. While it didn't cause any harm, I find it interesting that it acts as a sort of indicator that the PS is not hooked up correctly.
Return to “Fractional Rack Modules”
