Juno 66 filter CC problem
Support and discussion of Tubbutec products.
Moderators: Kent, tubbutec
Venera 9
Post by Venera 9 » Tue Mar 13, 2018 11:10 am
Hey, when I sent my Juno a filter CC message from my Cirklon, the filter was closing when it should've been opening. IE, higher CC values closed the filter.
Thoughts?
tubbutec
Post by tubbutec » Thu Mar 15, 2018 6:36 am
Can you confirm the cirklon is actually sending the midi values normally and not reversed?
Maybe there is a setting in the cirklon?
Venera 9
Post by Venera 9 » Thu Mar 22, 2018 4:15 pm
I can confirm that it's not the Cirklon. I sent the same CC message to my Evolver and it responded the correct way.
Venera 9
Post by Venera 9 » Tue Apr 10, 2018 6:45 pm
So...is there anything else I can try?
tubbutec
Post by tubbutec » Wed Apr 11, 2018 2:28 am
The only other reason for this happening I can think of is an incorrectly installed filter wire.
Can you post a picture of the installed wire inside the Juno? (the orange wire)
Return to “Tubbutec”
