OSX, Batch renaming of samples: any tools ? simple ?
Author OSX, Batch renaming of samples: any tools ? simple ?
Funky40
OSX in my case
I need a Tool to edit the names of a bunch of samples in a batch.
example: "sample_11_ct9_e1
in this case would i have to turn "ct9" to "ct11" on all samples, if possible just by editing one sample or a dialog box.
if there are many options: i need something simple.
i was for example never able to batchconvert anything with wavelab
( have wavelab elements now )
sduck
I use renamer all the time for stuff like this.
https://renamer.com
Ramases
I think you already have a tool that can do it.
Automator, which is built into Mac OSX, has a batch replace text in a filename function.
It's free so worth trying anyway smile
https://www.wikihow.com/Batch-Rename-Files-in-Mac-OS-X-Using-Automator
flx
Another option, really easy to use and free:
https://mrrsoftware.com/namechanger/
Funky40
Great, i give them a try.
Much Thanks !
grillo
You can do a simple string replace with finder. Select multiple files, rename and then select replace text in the menu.
Monotremata
Nice did not know you can now do this in OS X directly heh. Ive been using A Better Finder Rename for years to do it.
Funky40
ahh wow, this works, and is supersimple !
while the free app above was not working in my now relevant case
much Thanks !
bobbylandry
This is what I use to shorten file names down to 16 characters for my MPC. Easy and lots of useful options on which part of the file name it acts on and how to change it.
ersatzplanet
I use Name Mangler. Does everything I can think of to file names, sequential numbering, Find and replace, insertion, even more (over 10 things in the pull downs) and advanced scripting for complicated things where you want to make formulas.
https://manytricks.com/namemangler/
francoprussian
You can also use the command line Terminal to do this. It's a bit more involved than Finder or Automator though.
The Grump
Myriad. Also super useful for batch conversions things like file formats, sample rates, etc..
Loopy C
My favorite (I batch process file naming everyday):
http://www.publicspace.net/ABetterFinderRename/version10.html
