Mutable Instruments Stages
Moderators: Kent, lisa, luketeaford, Joe.
Are you sure it will work while power is on? Maybe Stages would have to be rebooted to realize the wiring.
We are the Borg. Resistance is equal to voltage divided by current.
https://soundcloud.com/logic_not
current 9U: https://www.modulargrid.net/e/racks/view/428567
Skiff: https://www.modulargrid.net/e/racks/view/818039
Recording: https://www.modulargrid.net/e/racks/view/1392937
Video: https://www.youtube.com/playlist?list=P ... PvexiFtvhI
- moncks_crossing
- Common Wiggler
possible problem maybe:
It depends how stages boots. I guess on power up it checks some kind of ID on the connection to find out how many stages there are. If a connection is established but no ID is coming there might be a problem. Just a guess.
- kineticturtle
- Common Wiggler
Isn't the connector like a 4 pin connector? Just get a 4p2t switch and wire it inline. I would bet (and I'm just making an educated guess here) that even if you flipped the switch while the unit is on, the leftmost mode could be changed to oscillator mode without any problems. Worst case scenario one crashes, I can't imagine this would do any permanent damage.
Anyway thanks for this thread popping back up, I didn't even know about the easter egg mode, I'm enjoying the heck out of it. :)
FS/T: Various Euro and ConVertor+
I stream music making and LEGO on my Twitch channel.
Maths is hard, let's go shopping.
- CaptainRockout
- Common Wiggler
EDIT: Did not read far enough back. I should have known someone would have already tried a firmware solution
Last edited by CaptainRockout on Sat Mar 23, 2019 6:39 am, edited 1 time in total.
- moncks_crossing
- Common Wiggler
Videographics
- Common Wiggler
- moncks_crossing
- Common Wiggler
But how does this work with 2 modules chained - can you still put one in harmonic mode with the long button press?Videographics wrote:Did the last few posters miss the posts about the alternate firmware that switches with a long button press?
But this can’t be done with 2 modules chained.Videographics wrote:(BTW, it’s a 3-pin cable that links the modules and enables the Easter egg on startup with the original firmware.)
- joeSeggiola
- Common Wiggler
- Contact:
I'm the author of that firmware edit. Unfortunately I don't know, and I only have a single Stages, so I can't make tests. My hypothesis however is that it will behave strange or erroneously. Probably the one you put in ouroboros at runtime will function correctly, but the other one will still think to be chained, and act accordingly. I really can't tell :(moncks_crossing wrote:But how does this work with 2 modules chained - can you still put one in harmonic mode with the long button press?Videographics wrote:Did the last few posters miss the posts about the alternate firmware that switches with a long button press?
- forestcaver
- Ultra Wiggler
- Contact:
It wont function correctly :-)joeSeggiola wrote:I'm the author of that firmware edit. Unfortunately I don't know, and I only have a single Stages, so I can't make tests. My hypothesis however is that it will behave strange or erroneously. Probably the one you put in ouroboros at runtime will function correctly, but the other one will still think to be chained, and act accordingly. I really can't tell :(moncks_crossing wrote:But how does this work with 2 modules chained - can you still put one in harmonic mode with the long button press?Videographics wrote:Did the last few posters miss the posts about the alternate firmware that switches with a long button press?
I’ve done some similar changes that also passes the ouroboros state left and right to chained modules to switch them as well. I’ve only tried it on two modules but my concerns are the overhead (memory) on the right and left comms - especially with more than two modules.... I’d love to test it with six but....
- CaptainRockout
- Common Wiggler
I absolutely did miss them. Saw everyone talking about a switch expander and my first thought was "why not edit the firmware?" A shame it won't work for two Stages that are chained together as that is my situation too. Emilie recently posted this great diagram on the Mutable forum for a configuration using a DPDT switch: https://forum.mutable-instruments.net/t ... g/14853/13Videographics wrote:Did the last few posters miss the posts about the alternate firmware that switches with a long button press?
- Paranormal Patroler
- Super Deluxe Wiggler
Re: Mutable Instruments Stages
[MOD EDIT]
For clarity, and in order to keep things clean, this thread has been split. For Alternative firmware discussion please check
Alternative Firmware(s) for Mutable Instruments Stages
- cptnal
Resubscribing
You know you can do that via the topic options, right? You don't have to post on the topic for that to happen.
But yes, apologies, I'm not aware whether subscribers get unsubscribed when a topic gets split. I don't see why that would be the case, it doesn't make much sense, but still.
- cptnal
I do know that, but I wanted to show appreciation at the same time.Paranormal Patroler wrote: ↑Fri Aug 07, 2020 4:35 amYou know you can do that via the topic options, right? You don't have to post on the topic for that to happen.
thanks for the topic split. still need to find an afternoon to cook with the new variations.
Out of curiosity, has anyone ever looked into the feasibility of creating an expander, connected via the 3-pin daisy-chain header(s)? Maybe something with 6 CV inputs for the knobs, and 6 "end of segment" gate/trigger outputs with LEDs?
WTB: original MI Rings panel
Also looking for someone willing to make a couple small changes to Rings firmware
is it possible to have level (amp) control over an lfo via a slider?
i guess its possible using 2 segments?
autopoiesis
Yeah, you'd need to use two segments if you really wanted to use a Stages slider to scale the amplitude of one of its segments. For looping ramp segments, the slider only controls LFO frequency — the factory firmware doesn't work like Batumi where the sliders get repurposed for different functions depending on button states.
Ok good to know. Yes, maybe its overkill to use one segment of stages for something that a attenuator or a attenuator cable can do.
Btw does it sine lfo as well or only triangle, square etc.?
- starthief
- Contact:
It'll do sines.
thanks. i know it has been asked in the past.
is there a way to cv the shape parameter- maybe via an alternative firmware?
when fming a lfo (at the time/level input) the gate input is redundant isnt it?
- mother misty
- Common Wiggler
That's not possible, it's probably possible with alternative firmware, but I'm wondering how you would control that without giving up something else?
No it's not, with the gate input you can make a syncable LFO, the slider acts as a clockdivider (remember to patch from the right) without gate you have a free running LFO (patch from the left)
Have the Stages for two years and never noticed that clock divider thing (never tried to use a clock as an input). Thanks a lot for that tip!!!mother misty wrote: ↑Tue Jan 12, 2021 9:03 amThat's not possible, it's probably possible with alternative firmware, but I'm wondering how you would control that without giving up something else?
Maybe I'm missing something obvious, but how are you achieving this? I can offset an lfo by running it through a step or hold stage but I'm not sure how to attenuate it.autopoiesis wrote: ↑Mon Jan 11, 2021 5:04 pmYeah, you'd need to use two segments if you really wanted to use a Stages slider to scale the amplitude of one of its segments. For looping ramp segments, the slider only controls LFO frequency — the factory firmware doesn't work like Batumi where the sliders get repurposed for different functions depending on button states.
