ES-6 Mistakenly connected without ES-3
Author ES-6 Mistakenly connected without ES-3
s0lo
Because of my initial ignorance. I've used the ES-6 without connecting it with the ribbon cable to the ES-3 d'oh! . Obviously it didn't work. Will that damage the ES-6?
The problem now is after doing the right thing and connecting the two modules together. The ES-6 gives me very high aliasing like noise on ports that are not connected to a cable. Also even with the ports connected, it gives some lower jitters and noise.
These noises come and go. like within every 10 seconds.
Any idea?
I doubt you've damaged the ES-6.
What's your audio interface? DAW? Computer setup?
s0lo
I'm using MiniDSP USBStreamer
DAW: FLStudio
Computer: Lenovo ideapad 305 laptop
So the USBStreamer is your only audio interface? Nothing else for monitoring etc.?
s0lo
I used a fast track pro for monitoring. Aggregating both interfaces through ASIO4all. But I think I also tried with only the USBStreamer hooked, same problem. Can't remember for sure, I tried so many things.
I actually got me an ES-8 now!!. Works perfectly, lets see if the ES-6 works with that.
