Lightpipe to MIDI
Author Lightpipe to MIDI
auricle
Hi all,
I'd like to get whatever Eurorack modules I need to get stable MIDI from a lightipe connection. If you don't mind answering a couple of questions as I'm totally new to Expert Sleepers modules, I'd be grateful!
1) Which modules do I need? I need 24 MIDI outs.
2) I use Silent Way to interface Ableton Live with the modules. Do I use one SW instance per MIDI port? Or how does it work?
3) Can I use the same lightpipe connection to have CV+Gate outputs as well as MIDI?
Do you mean 24 individual hardware MIDI ports? Or 24 channels (on a smaller number of ports)?
auricle
Hi Os,
I meant 24 individual hardware MIDI ports.
Then you would need
- an ES-3
- an ES-5
- three ESX-8MD
One plug-in instance per MIDI port.
You can use the remaining channels on the ES-3 for CVs and the ES-5 for gates.
auricle
os wrote:
Then you would need
- an ES-3
- an ES-5
- three ESX-8MD
Thank you!
auricle
I just placed an order for these modules on Schneidersladen. A couple of things are out of stock so I have to wait a bit - but that's okay.
Are there any special cables or anything also need to be ordered to make this little ensemble work together?
Just a TOSlink cable.
auricle
Great, cheers Os.
