Author |
patchbay hum |
br>Granny |
br>hello,
so i got myself a patchbay with balanced in/outs and i use stereo-patch cables. on my mixer i use unbalanced aux channels, and my effects have unbalanced in/outs, too
when i use any synth through an effect with the aux of my my mixer - no hum
when i involve the patchbay - hum
most effects, mixer and patchbay are build in a rack
any tips? is it a problem that the patchbay is balanced in/out and the rest is not?
i just ordered some humfrees that i will try br> br> |
br>Kent |
br>You need a grounding scheme for your entire studio system.
In my system, all of the grounds are lifted on the input side of the gear. I can explain in greater detail over the phone or Skype if you want to give me a call. It’s complex stuff but, once sorted out, pretty much guarantees a ground-loop free system. You won’t need the ‘humfrees’.
Drop me a line. br> br> |
br>Granny |
br>Thank you, I just googled 'ground lift' trying to make some sense out of it. Thanks a lot for your offer, I'll pm you when I have questions br> br> |
br>BugBrand |
