Disting Mk4: possible to add a variable buffer algorithm ?
Author Disting Mk4: possible to add a variable buffer algorithm ?
loorenz
A friend of mine have bought this little AJH module that I find it useful in some specific case. It's great to be able to adjust sometimes small tracking problems without unmounting and having to re-calibrate with the trim on the back of teh module.
Here is the module :
http://www.ajhsynth.com/V-Scale.html
It's a buffered multi with this added feature: some outputs can be adjusted up or down by +/-5%, so that it's easy to compensated 1v/o tracking.
Would it be possible to add this feature in a next Disting firmware .
It's possible - I'll make a note.
loorenz
Great !
hope it will be a future algorithm thumbs up
drewfx1
+1
If this could be a parameter added for quantized algorithms outputs, this would solve a big problem I have with certain ill-behaved VCO's.
Otherwise, maybe it makes sense to just add an output scaling parameter to the Precision Adder?
