Robaux SWT16
Author Robaux SWT16
OB1
I see the SWT16 is now available in kit form...
http://robaux.co/swt16
Gonna have a go at building one I think - anyone else tried it yet?
Jarno
Hadn't heard of it, but that's a pretty cool thing.
NANO-Jorge
Pretty cool module, haven't tried it but looks nice.
OB1
Yeah, looks great! Just what I've been looking for in fact. Was hoping for a PCB/panel option, but that doesn't seem to be available at the moment, so I'm gonna bite the bullet and order the kit.
masterofstuff124
i bought the pad combo from adafruit in anticipation of this build but i only see a kit available. sad face.... Dead Banana
OB1
I very nearly did the same myself today, but, in a rare moment of sanity, checked if the PCB was available before pulling the trigger rather succumbing to my usual “oooooh blinkenlights, buy buy buy” impulse!
jimboburgess
I built one, looking into the update which allows up to 64 steps.
OB1
Yeah, I've not done the update yet - I updated from 1.0.6 to 1.0.7 no problem though and even modified the firmware to display my own name rather than "robaux" while at rest, so don't anticipate any issues with the update to 1.1.0
jimboburgess
Is you name more that six letter?
can you just add extra lines to the code?
byte animations[24][10] = {
/* STEP */ {3, 2, 1, 4, 5, 10, 11, 14, 13, 12},
/* TAP */ {0, 1, 5, 9, 13, 14, 10, 6, 2, 3},
/* RANDOM */ {15, 10, 7, 2, 1, 0, 4, 8, 9, 12},
/* DELETE */ {12, 8, 4, 0, 1, 2, 7, 11, 14, 13},
/* MUTE */ {12, 8, 4, 0, 5, 6, 3, 7, 11, 15},
/* FILL */ {10, 9, 12, 8, 4, 0, 1, 2, 3, 69},
/* INVERSE */ { 1, 5, 9, 13, 14, 10, 6, 2, 69, 69},
/* PERFORM */ {9, 10, 7, 2, 1, 0, 4, 8, 12, 69},
/* LENGTH */ {0, 4, 8, 12, 13, 14, 15, 69, 69, 69},
/* LENGTH RESET */ {0, 4, 8, 12, 13, 14, 15, 7, 3, 2},
/* GATE */ {11, 15, 14, 13, 8, 4, 1, 2, 3, 69},
/* CLOCK */ {15, 14, 13, 8, 4, 1, 2, 3, 69, 69},
/* AUTOPLAY */ {12, 8, 9, 4, 1, 2, 7, 10, 11, 15},
/* NOTES */ {12, 8, 4, 0, 5, 10, 15, 11, 7, 3},
/* WRITE */ {0, 4, 8, 12, 9, 10, 15, 11, 7, 3},
/* UTIL */ {0, 4, 8, 13, 14, 11, 7, 3, 69, 69},
/* HOME */ {13, 9, 5, 4, 1, 2, 7, 6, 10, 14},
/* INSIDE */ {8, 4, 5, 1, 2, 7, 11, 10, 14, 13},
/* r */ {7, 6, 5, 8, 12, 69, 69, 69, 69, 69},
/* o */ {13, 14, 11, 6, 5, 8, 69, 69, 69, 69},
/* b */ {0, 4, 8, 12, 13, 14, 11, 6, 5, 69},
/* a */ {8, 13, 14, 15, 11, 7, 6, 5, 69, 69},
/* u */ {4, 8, 13, 14, 11, 7, 69, 69, 69, 69},
/* x */ {4, 9, 12, 7, 10, 15, 69, 69, 69, 69}
OB1
I haven’t looked into the code too far, so not sure how easy adding extra letters is. I just did “OB1” twice!
I’ll have a proper look at the code this evening and work out if it’s feasible to add extra animations to the array.
ludotex
Built one. It's great fun.
A couple of questions:
The LEDs are way too bright for my eyes though.
Which resistors should I change or is there an easy hack to make them less bright. Maybe I ll put some stickers on the buttons meh
Also since it's not arduino how do you update the firmware now?
cackland
You can still update the firmware through the Arduino IDE.
euromorcego
yes, they are. I should have known that a 220R resistor for a clear led is way too bright ... 1k would probably result in a more pleasant brightness.
Unfortunately, there are many led resistors, the schematic is available. It is the 220R (all of them). To exchange/de-solder them later is not going to be easy. Maybe there is a way to do this in software?
As for the other question: As mentioned it is still an ATmega. But update is a bit more tricky (I think you can do with an arduino and some extra components). For me also update via usb would have been more convenient.
Otherwise a great module!
timpecter
I was really keen to get a kit from Thonk but they sold out quickly! Hope they will restock soon.
soggybag
I just ordered one of these from Modular Addict.
tobywan
Hi there,
Got a question for any SWT-16 owners out there. Built one the other day and really like it, great little sequencer!
My question or query is this. Both the Clock and Reset inputs seem to be outputting a steady 5v signal which seems odd right? I only noticed this when I tried to clock the SWT-16 with Tempi and I couldn't get it to run at all [It works fine with 2hp CLK or a square wave from Batumi].
I had multed Tempi into a MN Shared Bus and when I plugged the clock from one of the mults into the SWT-16 I noticed the indicators went from a pulse [from Tempi] into a steady positive voltage. I guess the Tempi Clock just got lost amongst that and the SWT-16 wouldn't run.
I figured out the only way to use Tempi with the SWT-16 was to run the mult out through an attenuator [Maths or S.P.O] which I guess have some sort of Diode on the outs that stop the 5v signal being fed back in to the Shared Bus.
Can anybody else verify if this is the case with their units? I think my build is pretty solid and I noticed there are no Diodes on these outputs on the board [whereas the trigger outs do]. Everything else works like a charm on it. It's a Rev 2 unit.
Just curious as it seems like odd behaviour for inputs to be sending out a signal like that. I've treble checked my soldering [grounding on the power etc] Any thoughts?
All the best
bandobandobando
I got an issue with my robaux swt 16.
I bought a built one off reverb. It had the older firmware and I wanted flipped UI so I tried to upload the latest version. I followed the steps per robaux /modern.com tutorial but the upload failed a few times in arduino ide after compiling ok, then I tried to use ATmedga328P (old Bootloader) which seemed to upload the ino file successfully, maybe that's where things went wrong. Alternatively, maybe setting the module down disconnect wire/solder, though the top board seems to be connected ok to bottom via the 4?pin cable. In any case, the front lights all stopped working including the menu button. I eventually switched to a new computer and updated the firmware successfully and the arduino nano seems to be working fine (here's a video of it processing an eg ouput through the trigger input https://youtu.be/3W-C6lpg1Vc ).
Any thoughts?
