FH-1 & Iconnectivity MIO issue
Author FH-1 & Iconnectivity MIO issue
JoPo
I'd like to know if it's possible to connect the FH-1 module to the MIO = https://www.iconnectivity.com/products/midi/mio10 in which one can connect a 10 port USB hub for any midi class-compliant device ? That would allow me to control the FH-1 directly from my daw. (Apparently, it should work, according to this thread : https://www.muffwiggler.com/forum/viewtopic.php?t=130739&start=25 but I'd like to be sure !) hyper
For instance, I connected my Behringer BCF 2000 and it works like a charm. Can I do the same with the FH-1 module ?
Thanks a lot ! smile
Yes you can connect the FH-1 to the mio10 (to one of its computer ports, not to a device port).
I just announced the FH-2 though.
JoPo
Ooops ! I forgot to thank you a lot !
JoPo
That's it !I installed the FH-1. When I connect my BCF 2000 directly into the module the USB led is on and it works perfectly.
But when I connect it either to my computer or to my MIO 10, it refuses to communicate. The led remains off.
Must say that after searching everywhere, I still don't know what to do !
Some help would be welcomed ! Thank you !
JoPo
Oh ! I forgot to say that I updated the firmware first of all.
And also, my MIO 10 is connectable to a usb hub and that's what I did. In the usb hub, there is already my BCF 2000 and an Xstation, there are working well and that's where I'd like to connect the FH-1 too.
The hub is powered and one can add 10 usb class compliant midi devices in it for the MIO 10.
I really scratch my head... Unable to find why they don't communicate.
You can't plug the FH-1 into a hub or one of the mio10's device ports. It would have to be plugged into one of the computer ports (same port you'd plug your mac/PC into).
JoPo
Ah ! Thanks a lot ! I read you already told me but I didn't notice that correctly...
It seems to work, now !
Merci !
