Northern Light Modular - 200h Modules, 2EM - Superbooth
Author Northern Light Modular - 200h Modules, 2EM - Superbooth
Synesthesia
Hello !
We are still tipping away with our h format modules - moving from early version prototype to more finish products.
Good progress on the 2EM too ... CV Controlled Evenmidi in the rack wink
- TrommelMaschine is our incarnation of Grids, with added benefit of the midi in
- Voltage Circus and Electric Dompteur are 2 original modules - more info to follow smile
all the h series will be available for DIY through Modular Addict.
Sascha will be at Superbooth and brought some modules with him - so if ever you happen to be there and have any question for us ... have no hesitation !
Synesthesia
livefreela
applause applause applause
sneaky drop on trommelmaschine! terrific names btw...
Synesthesia
wink it's a hell of a lot of fun with the 292 ! thanks!
Precarious
They look great!
I took the opportunity to have lunch with Sascha and demo the units. These things are very cool and will prove useful to those... that have a use for this kind of thing (me).
These guys are filling a void left by the quasi-disappearance of Eardrill. To wit:
Correlated LFOs and the 2TT to replace/complement the Pendulum/Ratchet.
We discussed a lot about the kits. I found them to be far too generously priced for what one gets. It is pretty amazing. These guys have a lot of interesting plans and ideas.
cygmu
I think that puts it perfectly.
pickleinn
excited to put some of these h modules in my kit. That hTM is awesome!
ArguZ
The idea of our h series is to offer some simpler concepts in bite size to a broader audience.
We are not sure how well the SMD DIY idea flies, but we think it is totally worth trying out.
We will label the kits in three classes.
1. Low different part count - no MCUs - no programming - no small pitch
2. Medium part counts - preprogrammed ICs we supply - no small pitch
3. High part count - MCUs - programming - small pitch
We do a batch of 50 of each of them and see how it goes.
If it runs smoothly we keep it as it is, if not we go to partially pre-assembled boards.
The tools to handle 805 SMD sum up to just a 100$...
And because of the high price of through hole components and their inevitable obsolescence we would like to use this opportunity to get more and more people into the world of SMD DIY.
The plan is that we will run workshops where you pay a fee and can build any kit under guidance.
ritchiedrums
Love This!! love
pickleinn
I have been doing through hole for about 15 years now and have just started with smd (2oc and 2x TSNM). For the parte on those boards I just used a finer tip on my soldering iron and all worked well. Had a couple of bridged on the dac but easily fixed.
All in all I think with a pair of tweezers and fine solder wire it is actually more enjoyable.
ArguZ
So this would be an example for Level 1
Example BOM , please do not order anything wink
And this would be the board...also not 100% done but to give you guys an idea
The BOM for this is like 25$ for the e-parts and around 20$ for the hardware smile
https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=1b74 e7cc95
The kits will be like 100$ in the US , so for like 150$ you can build a shiny new h series
jimfowler
very excited for these! infinite thanks for your hard work bringing this stuff to the masses.
pickleinn
Really awesome value. Thank you guys,for doing this. Really exciting to get more options in the buchla format
ArguZ
So yesterday we made the test.
This hVC has been built by a total layman who never had contact with modular before.
He knew how to to solder with an iron but he never touched SMD before.
It took 5-6 hours from scratch and he ended with a 100% working build.
The h bracket in the picture is the one from SAmodular with the 2,5mm metric threads
The front plate is still in prototype engraved state but the layout is final and production has started smile
DomMorley
nanners
