Expanding the ES-8 for iOS use
Author Expanding the ES-8 for iOS use
99centimos
I would like to use the ES-8 as my main iOS audio interface, only I'll need regular audio inputs as well, would any ADAT-equipped interface work? hmmm.....
Yes.
What do you need "regular inputs" for? Mic preamps or something?
99centimos
Line level... I'm assuming Es-8 is not suitable for connecting say a non-modular synth?
That should work fine. You might need to turn it up a wee bit, but try it before you assume you need to spend more money!
99centimos
I'll try! I will need mic input eventually, but in the meantime it would be great to be able to use just the ES-8...
