ES-3 and arturia audiofuse on Ableton
Author ES-3 and arturia audiofuse on Ableton
jaydo1
Hi
I have just got a es-3 & es-6 and an Audiofuse soundcard which I am using the adat out and in to connect to my surface pro
it kind of works but the numbering of the outputs channels seems to be off
example when i map the output to channel 7 it is channel 1 on the es-3?
when i load up Slientway software and try to select the correct output channel on the es-3 and it doesn't seem to get to the correct out on the unit?
has anybody else experienced this with and es-3?
Sounds like it's probably working fine. I imagine the main analogue outputs of the Audiofuse are outputs 1-6, and then the ADAT channels start at output 7.
darkgr33n
same thing using the focusrite, except channel 11-18 are the ADATs. Just name them in ableton and you're good to go.
