Piston Honda Mk3 Waveform Select CV Behavior?
MUFF WIGGLER Forum Index -> The Harvestman
Author Piston Honda Mk3 Waveform Select CV Behavior?
digitalohm
me again...
im noticing another behavior that may be expected but I'm not seeing it in the manual. When I have nothing plugged into the Piston Honda Mk3, turning the Waveform Selection CV attenuverters will alter the sound
can anyone else confirm this behavior?
direct link: https://vimeo.com/268724691
digitalohm
Scott helped me get this squared away this morning.
The fix was to self calibrate:
1. Make sure nothing is plugged into the piston.
2. Turn your system off.
3. Hold down the button next to the display. Turn the system on.
After performing this procedure the waveform select cv attenuverters no longer change the tone of the waves.
seriously great support from Industrial Music Electronics! thanks again!
