ES-7 with ES-40, no input signal
Author ES-7 with ES-40, no input signal
sushiluv
Hi, i can´t get a signal to my computer from the ES-7, it´s connected to the correct header, like it says on the ES 40´s PCB, the jumper is set correctly as well. the inputs on my ultralite are working (tested it with a s/pdif feedback loop, out to in, i get a signal) and tried everything else i can think of but no go.
Outputs to esx-8cv are working fine.
is there something obvious i´m missing here?
Any help would be much appreciated, also the cuemix fx software is a mess, just saying smile
Cheers!
sushiluv
to be able to record from s/pdif i have to set the motu sync settings to s/pdif, that´s where everything goes downhill, the motu display starts flickering and i get no audiooutput whatsoever, is this a known issue?
thanks
You don't want the sync settings set to SPDIF - the MOTU needs to use its internal clock.
You should be able to use the SPDIF inputs with the sync set to internal.
sushiluv
Thanks os, i can´t get any input signal, regardless of what i try.
i checked the spdif input on the motu, it does work wth other signals. The LED Rings on the ES-7 do work too.
could my unit be faulty?
thanks!
Cam I assume you're using two SPDIF cables, not just the one?
sushiluv
yes!
one cable spdif out motu -> ES40 in
another cable ES40 out -> spdif in motu
i also tried different cables
Could you post a photo of how you have the modules connected with the ribbon cable?
sushiluv
sure, thanks
That looks OK.
I'm out of ideas. Is the ES-7 brand new?
sushiluv
Yes, i bought it at schneidersladen.
i will try a friends Motu Ultralite just to make sure it´s not the interface that makes troubles.
I guess i have to deal with schneidersladen to get a replacement for my ES-7?
That would be the first thing to try, yes.
