ES-3 mk4 broken?
Author ES-3 mk4 broken?
timothyjr
Hi all,
The red light on my ES-3 mk4 won't turn on anymore and I can't get audio to come through. It's attached to an ES-6.
I've made sure everything is attached correctly, replaced the power cable, attached to a different power connector, attempted to run it without the ES-6... nothing.
Any thoughts?
What's the audio interface? Have you checked its settings (particularly, are you still sending ADAT not SPDIF out of the optical port)?
Have you checked the ADAT cable?
timothyjr
I'm connecting it to a MOTU Ultralite AVB. It's possible a setting was changed or that the ADAT cable is broken, but if I'm remembering correctly the ES-3 should light up on startup of the modular shouldn't it?
Only if it's receiving a valid ADAT signal.
timothyjr
Ah! Ok my memory is bad apparently. Let me go tinker.
