FH-1 midi CC init value
Author FH-1 midi CC init value
JoPo
Hi !
I'd like to if it's possible for a midi cc to be initialized to a value like 64, for instance.
In fact, when the FH-1 is turned on, I'd like the smoothing already to 64. I don't find that in the script.
"Init to mid-range" doesn't seem to have the effect I'm looking for.
Thank you !
Yes, it's possible. Use a HEX line in the script, or just set up a preset and save it as the default.
JoPo
Euh... For the HEX line, I need some time... hmmm..... Didn't find where in the manual. If you just could tell me on what page of the pdf.?
I saved the preset in slot 1, anyway ! Mr. Green
Look at the HEX that's generated by the script tool.
E.g. init to midrange on output 1 gives you
HEXB00040
or to break it down
HEX B0 00 40
B0 = CC on MIDI channel 1
00 = CC #0
40 = value 64 (in hex)
Similarly, smoothing on output 1 would be
40 = CC #64
40 = value 64
so
HEXB04040
JoPo
w00t!! That's perfect ! Many thanks ! I handle perfectly the FH-1 script, now ! w00t Brilliant !
