ES-3/ES-6/Ableton Setup: Will this work?
Author ES-3/ES-6/Ableton Setup: Will this work?
6667
I would like to know if this setup using ES-3, ES-6, and Ableton will work, and if it actually makes sense. Here is how I imagine the flow of cv and audio to look like:
Ableton (Host for SW vst):
-Has some channel with Silent Way plugin doing some stuff (sending gates/pitch/etc.)
-Channel will be assigned to the corresponding ADAT out channel on the audio interface.
Focusrite 18i20:
- Uses ADAT out port to send cv to ES-3 ADAT in
ES-3:
-ADAT in gets cv from the Silent Way plugins (gates/pitch/etc.)
-cv outputs will distribute these voltages to my modular system to control whatever
ES-6:
-Gets final audio output from my modular system
-Sends audio from ADAT out to audio interface's ADAT in
Ableton:
-Audio channel with audio input set to corresponding ADAT in channel records sounds from my modular
Will this work?
Basically the bare minimum I am trying to get going before trying to do some fancy shit is to be able to send an arp/sequence from Ableton to eurorack (or at the very least sync my eurorack using Ableton as a master clock and use a eurorack sequencer), and send the audio back to Ableton to be recorded.
Apologies if any of this doesn't make sense, I've never used ADAT "Lightpipe" in my entire life in fact I'm not entirely sure I fully even understand the concept but yolo
Also can I send midi to ES-3? I don't understand I'm confused seriously, i just don't get it
Yes that will all work.
ADAT isn't mysterious. Just think of it as eight audio cables in one.
As in, MIDI to send on to MIDI synths? Or do you mean use MIDI to control the notes/pitches/CVs you're sending out of the ES-3?
6667
That's it-- I'm wondering if I can have a regular MIDI clip in Ableton to control notes/pitches that I'm sending out of the ES-3.
Edit: Also would like to know if an ES-3 MK4 will work okay with an ES-6 MK1.
Yes - use Silent Way Voice Controller.
Yes.
