Making Cv cables, new happy user :)
Moderators: Kent, os
isak
Post by isak » Tue Aug 10, 2010 8:03 am
first i want to say when i found out that i can control CV with a software i was amazed, thank you for this great thing :)
before i ask the questions i wanted to ask an important question..if i have a VCF CV in from a synth (x0xb0x) can i do an automation to the filter in cubase?
i use RME's FF400, my DC outputs are 7/8 (its 2 mono outputs in one jack)
can i use both mono outputs as CV?
if i can use both mono outputs do i need to use this cable ?
An alternative is to wire a TRS jack to two TS jacks, connecting one T->T/S->S and the other R->T/S->S.
if i need to use this cable i didnt understand the ring connection..
this is what i understood by now..
TRS tip to TS tip, TRS sleeve to TS sleeve, whats next?
do i need to connect the TRS ring to the TS tip and the sleeve as well?
thanks and waiting for u'r reply,
Isak E.
Post by os » Tue Aug 10, 2010 8:15 am
Yes, if your synth has a filter CV input, you can automate that in Cubase.
The FF400's DC-coupled channels are the headphone outputs, as I recall, so the jack is a stereo output. You can use both of the channels to send CV.
You need what is commonly called a 'Y' insert cable, or simply a stereo-to-mono splitter:
http://www.soundonsound.com/sos/jan02/a ... chor-41113
isak
Post by isak » Tue Aug 10, 2010 8:23 am
thank you very much :)
bil_g
Post by bil_g » Wed Aug 11, 2010 5:46 pm
Fireface user here. Check out the Hosa/Livewire YPP-117. It has female TS(mono) outs. It's nice when you just want to use one channel or have Moogs with CV/Gate in/outs on the same jack.
isak
Post by isak » Wed Aug 11, 2010 5:52 pm
thanks man i'll check it :)
i made the Y cable :yay:
can u help with something els..?
viewtopic.php?t=20243
thanks again :tu:
Return to “Expert Sleepers”
