FH-2 and IPAD with lemur
Author FH-2 and IPAD with lemur
mDang
Hello,
i'm actually use this configuration FH-1 + iconnect midi + ipad 2 with lemur,
and i'll would like to know if i understand right :
with the FH-2 no iconnect midi is required ?
if yes, does the fh-2 will charge the ipad 2 ?
thanks
maxime
You wouldn't need the iConnectMIDI but you would need the Apple Camera Connection Kit. There's a version of that that lets you charge at the same time.
mDang
that's prefect ! less weight in the bag smile
mDang
is it this : https://www.apple.com/fr/shop/product/MD821ZM/A/adaptateur-pour-appare il-photo-lightning-vers-usb
This is the one with the charging pass-through:
https://www.apple.com/fr/shop/product/MK0W2ZM/A/adaptateur-pour-appare il-photo-lightning-vers-usb-3
mDang
ok, thank you wink
Videographics
Came to this thread looking for info on using Lemur (on iPad) with the FH-2. Anyone doing this? Experiences? Any good templates out there?
manglepup
I'm also hoping to figure out if anyone has found any good templates
reodjectz
I'm still confused about how to run the FH-2 with an ipad - then use a male to male USB?
Thanks.
No, USB A to USB C.
Unless it's an iPad Pro, in which case you don't need the camera kit and you can just use a USB C cable.
reodjectz
os wrote:
No, USB A to USB C.
That's great - I had everything I needed - I didn't realize the FH-2's USB-c was for anything other than programing the unit. TY VM! Got it up and running last night (patterning 2).
