Connecting both FH-1 (or FH-2) and ES-8 to iPad
Author Connecting both FH-1 (or FH-2) and ES-8 to iPad
99centimos
Is it possible to have both modules fully working at the same time vía an USB hub or something like an iConnectMIDI4+?
Yes, just tried it:
Code:
iPad
camera connection kit
hub
ES-8        FH-2
Da Dah Da
Hello, i’m looking to connect my iPad Pro 10.5 to my studio, i have a Fh-1 and want to add a midi usb controler for thé iPad apps (Seaboard block or Joué), a iconnect audio 4+ for iPad audio and midi DIN and a ES-8 for Audulus.
iPad
l
iconnectAudio4+ USB 1
iconnectAudio4+ Host
l
USB HUB
l l l
FH-1 USB midi controler ES-8
Does it work ?
Thanks !
That would work with an FH-2. With an FH-1, you'd have to connect it to one of the iconnectAudio4+ USB ports.
Da Dah Da
Thanks os !
I see an other problem, iOS can’t agregat 2 audio interface (ES-8 and iconnectAudio) maybe a iconnectMidi and a usb audio interface with adat is a better choice, more flexible in the case where i don’t use my modular.
I wonder if for iOS, ES-8 with an audio interface plug in the adat in/out is seen as a single audio interface ?
Yes, as far as iOS is concerned there is only the ES-8.
