Clock pulse width standard?
Author Clock pulse width standard?
BTG
I assume most devices that sync to external clock only look at the edge and not the pulse width, however I've seen some (eg. GRP R24) that specify a max duration (100ms in the R24's case) and I've seen others that recommend a range for clock pulses (from memory I want to say that 10ms duty cycle seems to be the norm).
Is there an actual standard of sorts that's safe for people to target?
