Joranalogue SELECT 2 - Dual Gated Precision CV Processor
Author Joranalogue SELECT 2 - Dual Gated Precision CV Processor
joranalogue
A fine selection
A 'Swiss Army knife' for your modular system, Select 2 provides two highly accurate gate-controlled voltage processors in 6 HP. These allow you to create, switch, mute, hold, invert, attenuate, offset, add/mix and subtract voltages, from slow CVs (control voltages) up to audio frequencies.
Each processor features two signal inputs, with the left input used by default. A gate on the 'select' input switches to the right signal input instead. The signal inputs are normalised to the precision +5 V reference (left) and 0 V (right).
Following the input section is a hold circuit. A rising edge on the 'hold' input freezes the input voltage at that moment, until the gate input goes low again. While most sample/track-and-hold modules only manage a few seconds, Select 2’s 'low droop' design enables it to store a held voltage accurately for several minutes.
The end of the signal path consists of a gated polariser/attenuverter. Using the knob, the voltage at the output can attenuated and/or inverted: the gain is −1 (inverted) at the minimum setting, 0 at the centre and +1 (unity gain) at the maximum. The polariser can be disabled using the 'unity' gate input. This unique ability enables a variety of interesting gate-controlled signal modulations. Dual-colour LEDs show the output voltage of each processor.
Finally, if the A output socket is left unused, the signal is mixed together with the B output. This enables signal offsetting, CV mixing, pitch transposing etc.
Superbooth demo—Select 2 starts at 9:57
[s]https://soundcloud.com/joranalogue/select-2-selection-drone[/s]
 [s]https://soundcloud.com/joranalogue/select-2-chopping-delay[/s]
[s]https://soundcloud.com/joranalogue/select-2-space-birds[/s]
More on SoundCloud: https://soundcloud.com/joranalogue/sets/select-2 (thanks to my brilliant test users for sending these in!)
Available now!
More info: https://joranalogue.com/select-2
ModularGrid: https://www.modulargrid.net/e/joranalogue-audio-design-select-2
Pricing: €160 / £140 / $160 (MSRP)
6 HP, 30 mm deep
cackland
Looks good. Any available demos on release?
ben_hex
Had the pleasure of testing this and just like compare 2 (watch this if you haven’t there’s a tonne of awesome patches to be had from something seemingly simple and utilitarian -https://youtu.be/jTylgi-7mqI ) its very very good.
joranalogue
I think ben_hex just answered that question! wink
For now, you can check out the Superbooth video and SoundCloud demos above (play them on the SC website to read the patch notes).
ben_hex
Trying my hardest to have a video ready for the release day too.
joranalogue
Some sweet track-and-hold tones in this quick video by DivKid aka ben_hex. Full demo video coming tomorrow!
D_Robot
Compare 2 is a fantastic module so intuitive to use and incorporate into a patch but with so much depth it constantly surprises me.
This one is definitely on my list, along with Filter 8, which I hope won't be far behind in being released.
Big thumbs up to Joranalogue
matttech
Pleased to be stocking all of these designs now! thumbs up
joranalogue
Select 2 is available now! https://joranalogue.com/select-2
Let's celebrate with another excellent, detailed demo video by DivKid. Check it out below - transposing, signal switching, ring modulation tones and some more clever applications:
And of course, a big thank you to everyone who supports Joranalogue Audio Design! w00t
D_Robot
Just rewatched DivKids video and now placed order with Matttech…
They support you well hihi
CaneMan
Just ordered from Perfect Circuit along with the Mix 3 and Switch 4. Can't wait to try it out! nanners
matttech
Rockin' Banana! Rockin' Banana! and...... shipped! thumbs up
D_Robot
Something for the weekend, sir?...
Nice w00t
j_dowe
When switching between two audio sources in the Select 2, how smooth does it cut back and forth?
joranalogue
Select 2 switches instantaneously. This is best for CV and allows you to do audio-rate switching, but may cause audible 'pops' when switching slowly between audio sources.
