Problem with k-5 programmable Quantizer
Author Problem with k-5 programmable Quantizer
gbraakman
The K5 always comes up with the error "cannot load log tables" .
I use the latest firmware 4.6 and have the logTables_16_20.bin file in the root of my SD card (which read all other files without problems)
What could be the problem?
Can I see a screenshot of your SD card contents?
gbraakman
Hi Thanks for responding:
For a minute I thought I had the problems solved because i noticed the log table was corrupt. The log files error disappeared. But now with the proper log file it says (if I read it correctly): "error using4 scl/kbm"
30 minutes later:
everything seems to work now. I deleted some files and a kbm definition, added the equal.scl which had some gone missing, and the error message has disappered.
So all good now?
