ES-8 right channel issue
Author ES-8 right channel issue
witchbutter
I'm having a strange issue with my ES-8, and I'm not sure how to troubleshoot. There seems to be constant noise coming through input 2. I am recording using 1 & 2 as left and right and the problem is obvious even with nothing patched in:
This then gets compounded because for some reason my Praga is bleeding through:
This is how I have the ES-8 set up. I have the ES-5 & 6 attached.
witchbutter
Also if I try to use input 3/4 even with the ES-5 and ES-6 disconnected the problem is actually worse:
Those are probably DC offsets. Use Live's Utility device and enable the DC filter - does that remove them (on the output of the Utility)?
witchbutter
Yes it does. Not sure why I didn't think of that.
