Es-8 with es-3,6, and 7
Author Es-8 with es-3,6, and 7
Matos
I looked in the manual but perhaps I overlooked it. How does one connect this series together? I’m assuming usb to es-8, then adat from es-8 to es-3. Does the adat from the es-6 go back to the es-8?
Yes. Also the ES-6's 10-way ribbon needs to connect to either the ES-3 or the ES-8.
technotourist
that was my question as well, so the be clear: In order to connect the ES-6 to the ES-8 i need to connect them both via the Expansion header as well as the ADAT ports?
Yes.
technotourist
Thanks, i am going to hunt down one of those short 15cm tos-link cables that i see people use.
https://www.rubadub.co.uk/expert-sleepers-optical-tos-15-cable
