Jaspers stands and heavy keyboards - what's your experience?
popvulture
Post by popvulture » Mon Jun 25, 2018 1:35 pm
So I'm looking at Jaspers stands on Thomann and am wondering what people think of the weight-handling capabilities. I see that a lot of stands have a two-bar support at the lowest setting, and some have them for the second tier up as well. My biggest wonder/worry is how sturdy and safe the higher tier, one-bar stands are.
FWIW I'll be needing a wider stand to fit a large 88 key Yamaha KX8 controller on the bottom, plus a Model D and a Juno 60, both of which are pretty heavy. Then lighter stuff on the highest rack or racks, depending on which one I get.
Thoughts? Basically just don't want something that'll A) wiggle around on me or more importantly B) not safely hold a keyboard.
Much appreciated! :goo:
With tusks.
Find me on ILF
pelican
Post by pelican » Mon Jun 25, 2018 1:57 pm
I have a 6 tier. Holds everything well, but if you’re worried you can add more support bars
WTB: Yamaha dx-11 manual
racooniac
Post by racooniac » Mon Jun 25, 2018 2:02 pm
here in the first photo you can see my jaspers hold a doepfer LC9 on the lower level ANGELED without even using the support bar on the backside.
on the second photo i am doing the same but on the top row with an different angle (and a mackie mixer is casually chilling on the top row without the need of a support bar)
these things are just awesome ;P
and for the very very heavy stuff, just start using the support bars ^^
popvulture
Post by popvulture » Mon Jun 25, 2018 2:33 pm
Cool, nice nice—thanks y'all. I figured as much based on people's positive reviews of these things, but it's nice to hear specifically how doable it is. Now to decide which one... :eek:
With tusks.
Find me on ILF
popvulture
Post by popvulture » Mon Jun 25, 2018 2:36 pm
Also the spaceship looks lovely :love:
With tusks.
Find me on ILF
Epicentre
Post by Epicentre » Mon Jun 25, 2018 5:03 pm
Here’s mine with JP4 & 6 and it’s super sturdy. You won’t have to worry at all.
thispoison
Post by thispoison » Mon Jun 25, 2018 6:08 pm
Must admit I'm a big fan of them and the only issue I'd look out for is to make sure the bolts are tight. They do need rechecking once the temperature has balanced, then they are great.
Where have I seen you before?
Same place you saw me, I expect.
I've got a good face for memories.
https://soundcloud.com/thispoison-1
popvulture
Post by popvulture » Mon Jun 25, 2018 6:42 pm
Fantastic. Also I must say that this thread is turning into a high potency GAS source :mrgreen:
With tusks.
Find me on ILF
GuyaGuy
Post by GuyaGuy » Mon Jun 25, 2018 6:53 pm
Are you guys playing/programing while on standing on ladders and squatting on the floor?
thispoison
Post by thispoison » Tue Jun 26, 2018 9:09 am
GuyaGuy wrote:Are you guys playing/programing while on standing on ladders and squatting on the floor?
Fair point there.
I basically use the Jaspers more for keyboard storage, moving anything I'm using at any point in time into the centre of the room (where there are Quikloks and X-stands to allow playing and programming). Space is definitely an issue..
Ranxerox
All the gear, no idea
Post by Ranxerox » Tue Jun 26, 2018 11:52 am
I have a four tier. You have to ensure you've tightened the knobs enough on the higher tier cross bars or they will swivel round and dump your keyboard overboard - had that happen to my Prophet 5 a couple of times soon after I got the stand. Luckily no harm was done, and I learned my lesson :-)
BugBrand
Knowledge of Bugs
Post by BugBrand » Tue Jun 26, 2018 12:27 pm
thispoison wrote:..
I basically use the Jaspers more for keyboard storage, moving anything I'm using at any point in time into the centre of the room ..
Ah, that's interesting - I got a Jaspers stand and couldn't for the life of me get it set up in a way where I felt comfortable with where the keyboards sat for actually playing. Everyone always sings their praises but I haven't clicked at all with them.
popvulture
Post by popvulture » Tue Jun 26, 2018 4:06 pm
Ranxerox wrote:You have to ensure you've tightened the knobs enough on the higher tier cross bars or they will swivel round and dump your keyboard overboard
That's precisely the bad scenario I was envisioning when I saw em. So if you get them tight enough, there's no worry?
With tusks.
Find me on ILF
estin
Post by estin » Tue Jun 26, 2018 8:16 pm
Do the support arms clamp around the round cross tube? If so use some fiber grip carbon assembly compound between the two surfaces. Its a gritty gel designed to stop movement or rotation of clamp connections. Great stuff.
Ranxerox
Post by Ranxerox » Wed Jun 27, 2018 2:20 am
Yes, once they are tight enough they will stay that way- they don't loosen over time.
After tightening, lean your weight on the brackets to ensure there's no movement before emplacing their precious cargo... that's what I should have done the first time!
jonne74
Post by jonne74 » Fri Jun 29, 2018 4:28 am
I have a 3-tier Jasper A-frame. Very solid with an SH-5, Juno-106 and King Korg. I've added some shelves below the bottom frame with even more equipment.
Seaweed Sound
Post by Seaweed Sound » Fri Jun 29, 2018 5:19 am
Jaspers is the shiznit.. it's a bit pricey importing it and adding extra accessories/arms but it's a solid investment
Sir Ruff
Post by Sir Ruff » Fri Jun 29, 2018 1:34 pm
BugBrand wrote:
thispoison wrote:..
Yes. The lack of quick release bolts (like on the old Ultimate stands) makes these an absolute PIA to setup (I have near PTSD from the sound of the hex key dropping on the floor repeatedly). Especially if you're someone like me who likes to rearrange things often. The support arms also require physical strength to pull off from the bars (if the plastic bracket doesn't snap on your fingers first). Really poorly designed from a musician's standpoint.
Unfortunately, they are the only option out there today, so if you need a racked setup then you just have to accept it. And fortunately once it IS setup, it is sturdy (unless of your you don't tighten enough and then, stuff starts swinging down :doh: )
coolshirtdotjpg
Post by coolshirtdotjpg » Fri Jun 29, 2018 4:22 pm
I have a HS-60 on mine, which is basically a juno 106, but with speakers, so it is way heavier. It's fine, but I keep it on the bottom row. I keep an Ensoniq ESQ-1 above it, which is not lightweight either. It doesn't seem to have any problems handling those. I keep a DX-21 is on top, but that doesn't weigh much.
New video on Prophet 12 Drone Patches:
venus_3036
Post by venus_3036 » Mon Sep 02, 2019 1:16 pm
Hoping for some advice on Jaspers stands and adjusting the depth of them - i'm looking at a 3 tier stand with adjustable max depth of 70cm - ideally i'd keep the depth to 50cm as i have a narrow room.. does anyone have any recommendations on the stability at varying depths? I have a couple 61 key synths i'd like to put on, one fairly heavy (20kg) the other more standard I suppose. I sent a query to Jaspers but their response did not give much guidance.
strettara
mufferthucker
Post by strettara » Mon Sep 02, 2019 1:37 pm
Here ya go:
I mean, unless you're living on the equator, in which case it should of course be sideways and I apologise.
"Music is man, described to man, in the language of things."
"A tape is interesting when it's an interesting tape."
"It must be abstract. It must change. It must give pleasure."
New EP: étude @ strettara.bandcamp
Dave Kendall
Set The Controls . . .
Post by Dave Kendall » Mon Sep 02, 2019 1:38 pm
By depth, I assume you mean front to back ? ( the distance between the uprights at the bottom of the "A" ?)
Jaspers stands will take some seriously heavy stuff if you use horizontal bars on the front and the back.
The main weakness is if you only use a single horizontal bar with a couple of support arms to hold a keyboard. In that scenario, you are relying entirely on the tightness of the hex bolts that keep the support arms at the correct angle, and the bolts that secure the horizontal bar into the "T" shaped pieces that hold them onto the sides (the "A ").
Adding more support bars doesn't really help much, as you still have basically 2 bolts stopping the horizontal bar from tipping over and depositing your keyboard on the floor.
(yes - a Kurzweil K2600X * nearly * did that to me years ago - lesson learned! )
If you use Horizontal bars front and back, it will be very stable, as long as it's not too tall, and if the depth is 50cm or more. If resting against a wall, even better.
Jaspers stands are really very good, as long as you don't rely too much on the bolts to stop things rotating. Something like a Nord electro 73 will be fine with just the two support bars on one front horizontal bar. For anything heavier, extra horizontal back bars is the way to go for peace of mind, as the rear of the support bars rest on them, stopping them rotating.
Want to Buy: KURZWEIL KSP8
"Everything in moderation, including moderation"
tioJim
Post by tioJim » Tue Sep 03, 2019 7:06 am
Sir Ruff wrote:PIA to setup (I have near PTSD from the sound of the hex key dropping on the floor repeatedly). Especially if you're someone like me who likes to rearrange things often.
Hahahaha, so true. I ended up strapping the hex key to my wrist :)
Jaspers stuff is awesome. Extremely robust and solid but yes at the cost of a quick setup and any subsequent tinkering.
I've added cable ties to supports that I fear could tip forward. Maximum weights are specified on the website.
My A-frame isn't extended to the full depth, it's at about 60cm, and doesn't effect stability at all. There is a cut-off point though as they're slightly lop-sided triangles so beyond a limit they'll be a bit tip-backward-y.
Here's my Jaspers rig. The monitor is a little high and I might actually fit the top bar to the rear support which will bring all the top row down and back a little.
Randy
Post by Randy » Tue Sep 03, 2019 11:22 am
If you really want a stand that will hold nearly anything, you could always make your own, which is what I did. I could not find a stand that I was confident would hold an 88 Rhodes and at least two other 88-key, weighted-action controllers, so I used some pipe (not tube) from the local builder supply, and a bunch of these:
http://www.alvinindustrial.com/product. ... ctTypeID=3
You should be able to find key Clamps (or Kee Klamps or whatever) anywhere in the world. Considering the price of the Jasper hardware, making your own is an interesting idea. I believe the stand I made is rated to hold nearly 2000 pounds.
venus_3036
Post by venus_3036 » Tue Sep 03, 2019 1:38 pm
Appreciate the detailed responses to my question - they do seem like a solid bet then :)
