Dynamic 'off tempo / humanized' feeling for synths
tanglefuzz
Post by tanglefuzz » Thu Jun 28, 2018 12:18 am
Hey everyone,
I'm trying to figure out how certain artists create synths that are changing their tempo while playing.
Examples:
(you can here it throughout the whole track at 2:20 for example).
I'm wondering if there are any useful techniques I could use to achieve effects like this. I know you can do it with manual midi programming, but maybe there's some easier ways to do this?
I've been playing with LFO's trying to get a similar change of tempo, but not yet getting the desired results. I do feel like I'm on the right track but I'm not sure.
I love how dynamic/human it makes a track feel, instead of having a synth play at exactly the same speed the whole track.
timoka
Post by timoka » Thu Jun 28, 2018 1:12 pm
there's no tempo change in that track or synthline, try playing with uneven divisions or multiplications for your sequence,
the doepfer A-160-5 ratcheting module can do these things for you. what you think is a different tempo is just a different meter or pulse perception over a plain old 4/4 130 bpm march.
edit:
ok i just tried something like that and it is not easy, simple meter changes are possible but the example you posted is shifting in time, not quite on beat that makes it a bit human and hard to do with just clocks. i suspect it's done by time streching the audio and pitch shifting it, so maybe it's possible to do with a fancy sampler? or then just programing a sequencer...
i also can think of just playing the clock by hand and sampling a good human sounding 2 bars or something like that.... anyway, good luck:)
MRoyce
Post by MRoyce » Fri Jun 29, 2018 1:40 am
Obviously this particular artists workflow could be whatever but there's a few possibilities:
1. Playing by Hand/Overdubbing the "out-of-time" bits
2. Nudging the MIDI-events in the DAW
3. Turning on a delay for just that part
4. Processing the recorded audio
mt3
Post by mt3 » Fri Jun 29, 2018 3:59 am
Modulate the master clock at a discretized fine level using a quantized sampl-and-hold, quantized to rhythmic permutations (aka not random).
jbuonacc
Post by jbuonacc » Tue Jul 03, 2018 10:32 pm
i think simply adjusting the Attack, etc on the envelopes can lead to similar results (especially when combined with an inverted env modulating the filter). pretty sure he was using "normal" gear and techniques. ??
GuyaGuy
Post by GuyaGuy » Tue Jul 03, 2018 11:28 pm
MRoyce wrote:Obviously this particular artists workflow could be whatever but there's a few possibilities:
5. Route a square wave LFO to control volume and maybe filter, route an envelope to LFO speed, adjust so that the LFO slows down
6. Unsync the arp which plays the doo-doo-doo type part but set it at the same BPM as the track, slow arp BPM by hand, speed it back up by hand
7. Unsync the arp which plays the doo-doo-doo type part but set it at the same BPM as the track, use an envelope to control arp speed
If I were to guess, 7 is what's happening because while the doo-doo-doos get off the grid they land at the same consistent tempos.
nuromantix
Post by nuromantix » Mon Jul 09, 2018 11:34 am
I think he's sampled a short line and is playing the sample back at different pitches/speeds. So when he plays a higher pitch, it's out of time.
orangehexagon
Re: Dynamic 'off tempo / humanized' feeling for synths
Post by orangehexagon » Mon Jul 09, 2018 12:58 pm
tanglefuzz wrote:I know you can do it with manual midi programming, but maybe there's some easier ways to do this?
I'm not trying to be obtuse or a jerk here, but why don't you just play the synth and capture the performance live?
it really seems like the easiest, quickest, and less-headache inducing way to approach that...
orangehexagon
Post by orangehexagon » Mon Jul 09, 2018 12:59 pm
nuromantix wrote:I think he's sampled a short line and is playing the sample back at different pitches/speeds. So when he plays a higher pitch, it's out of time.
i've used this technique before and the result would be a much more drastic deviation in timing with each new note
tito_tunes
Post by tito_tunes » Sun Aug 19, 2018 10:19 pm
Back to OP's question I think you're on the right track using lfos. I use maths to get a similar sound. If you have a cycling envelope and CV modulate the decay time it'll speed up the rhythm. You can use a sequencer to modulate the decay time and also retrigger your envelope so it syncs up again at certain spots.
danielriera.bandcamp.com
dogoftears
Puddle of Sealions
Post by dogoftears » Sun Aug 19, 2018 10:33 pm
sounds like a sawtooth lfo controlling a filter, and it's speed is sequenced a bit throughout (unsync'd LFO, or just weird/swung divisions). but the lfo is resetting on note trigs, that part is important.
you can make this patch on most analog style synths.
i really think it's sequenced, cus the artist is using the same handful of LFO speeds over and over.
music and mastering: http://xexify.com
Nelson Baboon wrote:I have made America great again.
Arguzeen
Post by Arguzeen » Wed Oct 03, 2018 6:05 pm
I'm not really experienced, but i see 3 ways to do it:
1) Loop on sampler with control over loop speed/length.
2) Cocos Reaper - each project tab can have his own speed/time signature.
3) Five12 Numerology.
