DELAYS - Boss vs Electro Harmonix
Author DELAYS - Boss vs Electro Harmonix
Rex Coil 7
BACKGROUND: I have Boss RE-20 Space echos. I have Electro Harmonix Memory Man With Hazarai (whatever the hell ~Hazarai~ is) and a Deluxe Memory Boy. I've also had the Boss DD-20 in the past (3 of them). Just to get it said, I also have an MXR Carbon Copy (sick little bitch!) ... and a Line 6 M13 (sick BIG bitch ... with MIDI I/O!).
I use one specified delay on each of a few separate instruments. ARP Odyssey, highly customized 5U modular, two Volca FMs tied together as a single 6 voice sound module, and a 1962 Hammond C3 which I've modified for use with either +4db/1.4v pro gear and/or Instrument Level 0.3v gear (so it's friends with stomp boxes AND rack gear). The C3 get's the Space Echo ... but the modular, the Volcas, and the Odyssey haven't been fully worked out just now. I also have a rompler and an Alesis SR-16 drum machine, both are stereo.
THE QUESTIONS: How do some of the smaller format (ie; stompboxes) Boss "DD" units stack up, especially for live performance real time use where on-the-run adjustments are made (for synth use)? Can they actually keep up with the GIANT ASS units named above? What of others? External controllers jacks for expression pedals or joysticks or other controllers are super handy, but not required (preferred, especially if they are useful).
Thoughts? Experiences? Opinions welcome.
Mr. Green
GuyaGuy
Keep up how? Feature-wise the DD series is obviously more limited. They're also blatantly digital delays. Even the analog setting is fairly clean with none of the roll off or grit from fancier modeling pedals. That can be a good or bad thing depending what you're after.
If you like the M13, you might wanna look at the M5--much smaller, same sounds, exp pedal etc. The XO series EHX Memory Man and Memory Boy also have exp jacks and both sound lovely for gritty, warbly analog, and they're very hands-on tweaky toys.
digitalganesha
Both the Boss DD-7, and my preferred the DD-3 are great on synthesizers. The DD-3 has a mode specifically to it where the speed at which you press the pedal determines the delay time, this makes it an incredible effect unit for varying stutter/glitch type effects. It's a Melt Banana secret. hihi
The EHX Number 1 Echo is as minimal as it gets but goddamn it is a beautiful sounding delay. It does suffer from the EHX plague of a volume drop when active, but if you use it at 100% wet on a send/return FX loop; its no issue.
The Memory Toy sounds like shit in my opinion. The Carbon Copy blows it away. The Deluxe Memory Boy and Memory Man are awesome (as you know having the DMBoy.) And Hazarai means "memory." That delay is also awesome and can do some wild things. Also, the majority of expression inputs on EHX pedals play nicely with CV.
Rex Coil 7
I've already owned 3 M5s, and an M9. Dumped for the M13. Had the M13 for several years now, during which I also used M5s for dedicated tasks (the digital ring mod is SICK with analog synths).
This is all excellent news. The Melted Nanaba secret is enticing. I'll have to look that up.
So I gather being outfitted with what I have pretty much takes the Apex Predator award as live performance delays go. I only just bought the Hazarai and the Deluxe Memory Boy not but a day ago (eBay). Paid $138 for the Hazarai and $128 for the Memory Boy Dlx (free shipping on both). Both appear to be in 5/5 condition from very reputable sellers. Also located a Ring Thing for $159 with 2yr add on warranty.
Unfortunately, I've yet to be able to test any of this stuff. My project modular is not quite completed yet (nearly there! ... see link in my signature), so when those things arrive I still have my guitars and an Odyssey to work them over. I have two Ernie Ball VP Jr. 25k pedals that can be used as expression pedals (when used with the proper cables, that is). I also have a custom passive joystick, each axis has it's own output ... so it may be used as a dual expression pedal.
I'm very pleased with the infos provided here so far. Thank you.
My chopped Tele with Strat neck ... named "Shredbilly" ... the top cut matches the profile of the Gibson Explorer. I have a fuddup neck injury, the cut was necessary to allow me to play guitar.
GuyaGuy
It means "slop."
http://www.jewish-languages.org/jewish-english-lexicon/words/225
Matthews claims another meaning. Might be an old school NY thing--or just made up.
“It means all the extra stuff. You know, give me a frank with all the Hazarai.”
https://www.premierguitar.com/articles/one-with-everything-the-story-o f-the-stereo-memory-man-with-hazarai-1
Rex Coil 7
It means "slop."
You're both wrong ...
Hazarai; "Big blue delay made by the company that is still trippin' on the same hit of acid it ate in 1969 with a bunch of really cool shit on it". Hazarai.
lol
GuyaGuy
It means "slop."
lol
Matthews definitely seems like he's still tripping on 1969 acid...
GovernorSilver
Mr. Green
If you're using one delay per synth, I don't see how you could get much faster than one DD pedal per synth, as far as on-the-fly tweaking goes. One pedal with just a few knobs per synth - can't really beat that.
One Hazarai per synth sounds too bulky to be practical.
Rex Coil 7
Mr. Green
Wouldn't that all depend upon how my studio is arranged? I wasn't commenting on various delay sizes as a matter of complaint, I was just joking around a bit.
The Deluxe Memory Boy and the Hazarai just arrived this morning. The Ring Thing just showed up a few days back. So I'll take some time, familiarize myself with these things, and see what gives. I already know the Ring Thing matches up quite well with the Odyssey .... perfect 5th interval at the press of a preset ... that's super nice. But there's a lot more in that gadget than just the ability to add "a second VCO" (so to speak).
The Odyssey has: Ring Thing, Waldorf 2-Pole, Boss PH-3 phase shifter, Electro Harmonix Poly Chorus, a custom chorus pedal I built for it (for all the world it sounds like VCO beating like no other chorus I've ever used ... glad I have seven more PCBs for that thing!!). So all that is left to dedicate to the Odyssey is some form of delay. It also has an Ernie Ball VP Jr. 25k volume pedal modified for expression pedal use which is used in the "expression input" of the Odyssey.
The fact that the Deluxe Memory Boy has an expression control input (compatible with CV signals, I've read) as well as the send/return loop jacks and that it is monophonic may end up being the dog's balls in my rig. The send/return jacks may be used to place FX on just the delay's repeats only (the original sound is not routed through the send/return loop). Dunno if that is useful yet, but there it is.
The presets in the Hazarai (along with reverse echo and a few other tricks) make it at least worth testing out. The lack of expression pedal input is a bit of a bummer, but not a deal breaker.
If I prefer one over the other (Memory Boy vs Hazarai) I'll sell the one that didn't work out and buy a second of the one that did work out.
If the whole mess turns out to be bad news, I suppose I can fall back on one of the Boss *DD* units (one of the little white ones .... I'd have to do research to work out which one suits best).
hmmm.....
GovernorSilver
For some reason, I missed the bit about all this stuff being just for studio use, not live.
Have you considered getting a patchbay? Would make it a lot easier to patch various synths to various delay pedals, as your whim dictates.
Rex Coil 7
I have two of the older Panasonics (32 jacks each). I've also collected 48 of the 1' long Dot Com patch cables which I like using with the patchbays. Being as short as they are, and as rigid as the "Synthesizers.Com" heat shrink tubing is, those one footers make a really nice *arc* which makes them easily swapped/moved around. The 2 foot ones also work just right for longer stretches between jack that are farther apart.
Half of one patchbay is used for an Alesis DEQ 8 channel 31 band digital EQ. Eight individual channels, each channel has it's own dedicated IN and OUT jack ... so 16 jacks on just that one EQ. But that thing is super cool. Holds up to 100 separate curves, and 100 separate programs, each program containing up to 8 curves. 12db plus, and 12db minus ... put two channels in series and you have 24db plus and 24db minus.
So, yea ... I have patchbays.
Ra
Just for the sake of mentioning more options: I've been pretty happy with the Boss DM-2w.
Has some nicely textured, foggy tone to it. I don't know if this is 100% legit, but there seems to be some kind of additional gate in the feedback path, which gets somewhat audible with feedback swells. When you start with a soft-attack sound, it gets sharper and pingier (?) with each repeat.
It also has a separate wet/dry output, which is always useful.
lol
So what is your excuse? Blotter, cube, microdot...? I preferred the windowpane.
Rex Coil 7
lol
Now you need to make up my mind here. Two years ago you said it was Purple Micro. I suppose at the end of the day ... "Fry" is "Fry" ... (a name for LSD back then ... "fry").
Blotter was quite popular in my stompin' grounds during the mid/late-70s, as was Orange Microdot.
That's all I'm givin' up in response to you. whistlin'
I created a Dot Com construct out of the fewest modules I could use to make up a voice with ... called it the "Micro Dot" ...
meh https://www.muffwiggler.com/forum/viewtopic.php?t=157075&highlight=
MindMachine wrote:
Purple Microdot here circa 1982.
Good luck on your ambitious project. Reading posts like this make me glad everyone is not as lazy as I am (... well I did make my own cases).
Your microdot also shows me I need to be more creative using my Q118.
lol thumbs up
Rex Coil 7
Ok ... after a few days of working with the Deluxe Memory Boy and the Stereo Memory Man With Hazarai ... the Hazarai takes the win.
I guess I just prefer digital delays over analog delays.
The ~Boy~ is up for sale!
(I've unsubscribed from this thread - I'm not upset, just trying to keep my number of subscribed threads under better control - if you wish to correspond please feel free to send me a PM, I'll be happy to hear from you - thanks!)
