ES-3 + ES-5 with Reason 10
Moderators: Kent, os
evileye0702
Post by evileye0702 » Tue Jul 03, 2018 12:05 pm
I've got an ES-3, ES-5, a MOTU 16A audio interface, Silent Way and Reason 10 running under Windows 7 64bit.
Has anyone had any luck sending gate/clock/trigger signals from Reason to the ES-5 using the Silent Way VST plugins?
I started by trying the SW Sync plugin in ES-5 mode but Gate 1/1 wouldn't come out the ES-5. Gate 1/2 would come out the first ES-5 jack but Gate 1/3 would come out jacks 1 & 2.
I'll be trying the ES-5 Controller next but I Want to make sure I'm not wasting my time.
I have no problems using the same configuration from Ableton Live to control my modular and I have a pretty good understanding of Reason, routing and the Silent Way plugins.
BTW, SW Sync and the other SW plugins I've tried work just fine if going to ES-3 just not the ES-5.
DJMaytag
Re: ES-3 + ES-5 with Reason 10
Post by DJMaytag » Mon Jan 07, 2019 11:33 am
evileye0702 wrote:I've got an ES-3, ES-5, a MOTU 16A audio interface, Silent Way and Reason 10 running under Windows 7 64bit.
The easiest way to send triggers and gates is to use the Silent Way Rack Extension. Plug your trigger/gate into the RE, then plug the dedicated trigger/gate audio output into whatever destination you’re using (ie ES-5 Controller VST’s optional audio inputs 1 thru 8).
I have an ES-3/5/8CV/8GT setup, so sending triggers to the 8GT (for my Euro drums) would need the ES-5 Controller set to send to Gates 3/1 thru 3/8 to utilize all the outputs of the 8GT for drums (8CV is set to channel 2, so that would be Gates 2/1 thru 2/8 if I wanted to send more gates to the 8CV).
Instagram | Soundcloud | Wisco Wigglers
If you talk about improper grounding 3 times, Graham Hinton appears!” -djs
DJMaytag
Post by DJMaytag » Mon Jan 14, 2019 9:26 am
Just out of curiosity, what versions of your ES-3 and ES-5 do you have (if you know)?
I think I have a decent grasp on how to set this stuff up in Reason now, as I was able to get MIDI clock out the other day to get a SUPER tight sync with a Roland TB-03. I've done Sync for Roland DIN Sync24 to a TR-606 in the past, but I'm having a little hardware issue right now, so I'd have to sort that out first before I could give some advice.
dlarseninclusive
I am trying to post a question about silent way.
Post by dlarseninclusive » Mon Aug 05, 2019 7:08 pm
and I need more reply posts to do it. sorry.
DJMaytag
Re: I am trying to post a question about silent way.
Post by DJMaytag » Mon Aug 05, 2019 7:23 pm
dlarseninclusive wrote:and I need more reply posts to do it. sorry.
huh?
dlarseninclusive
Post by dlarseninclusive » Sat Sep 28, 2019 8:02 pm
I need an additional reply post to add a new question about the ES-5, and I picked this one out of a hat. It is by far the most cryptic hardware I have ever worked with.
Return to “Expert Sleepers”
