es3, es5 and ESX-8MD + digitakt
Author es3, es5 and ESX-8MD + digitakt
smurf
Hi,
I have the above running from live and through a moto 828. Was wondering what would be the best way of then using the sequencer from the digitakt to sequence the modular too. So digitakt slaved to live es3 and 5 via ESX-8MD - so looking for a module that would convert digitakt midi to control the hardware. Hope that makes sense...
Can you not send the MIDI from the Digitakt back into Live, and then use the ES-3 to control the modular?
Failing that, an FH-2 would certainly do it.
smurf
great thanks Os. Forgot to mention I have an es6 - could this work with a midi to 3.5mm cable to input the midi and then send it back out the es3?
No. You would connect the Digitakt to the computer via USB.
