Sampler that thinks it's an oscillator?
Author Sampler that thinks it's an oscillator?
Mr D
Hi folks,
Are there any sampler modules that act like an oscillator?
By this i mean, you load up a sample and it just plays (and loops around) constantly, without needing to be triggered?
And preferably with a large amount of storage so i can throw in a few gigabytes of samples.
Wouldn't need too many features apart from that, so hopefully something not too spendy!
R.U.Nuts
You just described the Radio Music by Music Thing Modular. You forgot that it's only 4HP.
imrae
Disting mk3 and mk4 also have a "radio music mode". The Radio Music control layout looks great though!
Mr D
Nice!
And something with a leeeetle bit more features?
Like a display so you can browse your samples, select presets etc.?
And a bit more memory?
R.U.Nuts
The RM reads samples directly from SD cards with up to 32GB memory. Ain't that enough?
reodjectz
Mr D wrote:
Nice!
if you want a display go with the assimil8or from rossum.... but you'll have to set it up to loop (don't own it don't know if you'll need a trigger to start).
The STS has a looping mode that would work how you describe (have to turn it on by holding down the play button, then it loops fo-eva')
isol
The sweet sweet morphagene!
With the new firmware update is like a giant sampler wavetable with 1v/o tracking
freqout
seconding this. it can be nice to record a long droning note with something modulating its timbre, then dial down the gene size to be a small window of it and then modulate the slide input to shift the timbral quality
Dragonaut
Why not an e352?
peng
http://www.orthogonaldevices.com/er-301
Shledge
1010 Bitbox can easily do this.
What you're describing is something most samplers can do anyway.
xenosapien
Ginko Synthese┬┤s SampleSlicer.
Tonefloat01
Shledge wrote:
1010 Bitbox can easily do this..
+1
Not only that but you can change the firmware and turn it into the Synthbox as well. Rockin' Banana!
