Buchla 275r reverb tank specs?
Author Buchla 275r reverb tank specs?
levelhead3
Am having a difficult time determining the correct reverb tank specs for the Buchla 275r module.
I've seen a picture of a Djangosfire build with 1BC2A1B (grounded i/o) tanks, but another thread here mentioned using BC2E1 (no outer channel) tanks for a 208.
Given that both spec BC for the input & output impedance it seems safe to assume that's correct, but I'm not so such about the connector spec. Will A vs E matter and if so is there a better choice?
Peake
Djangosfire wrote in another forum that the 1BC2A1B works correctly. Edit: Xpander has them.
levelhead3
