Using Easel keyboard to trigger modular.
Author Using Easel keyboard to trigger modular.
mousegarden
Is it possible to use the Easel keyboard outputs to control my Euro gear? I guess I'll need a CV converter to match voltages?
Umcorps
https://www.modulargrid.net/e/synovatron-cvgt1
Job done. Both ways.
mousegarden
Thanks, I just couldn't remember what it was, I feel guilty for being lazy now!
Umcorps
Disting Mk IV also does 1.2 to 1v/oct and vice versa (who would have thunk) but you have to make your own nanajack cables and work out another way to connect the Easel ground to your Euro to avoid problems with the keyboard. So its handy if you're space challenged or just need a quick occasional solution but the CVGT1 way better if you have the space.
hermbot
The Disting also does the normal gate to Buchla gate conversion, in addition to the 1.2 to 1. I was looking at a CVGT1 but realized the Disting would probably get me by for a while...
Disting Manual wrote:
This algorithm is for interfacing Eurorack (or more generally, any analogue synths using the
1V/octave standard) with Buchla synths.
Input X/Output A convert a pitch CV from the 1V/octave standard to the 1.2V/octave standard.
Input Y is a gate input, triggering when the level exceeds 1V. From this, a Buchla-format combined
gate & trigger is generated from output B. This is a 4ms pulse at 10V, followed by a sustained gate
at 5V.
mousegarden
Thanks, I'm OK for space, so I'll go for the CVGT I think.
I just fancy having a bit of fun triggering my Euro modules from that Easel keyboard.
