ES-8 + ES-6 sample rate
Author ES-8 + ES-6 sample rate
mdoudoroff
If I add an ES-6 to an ES-8, does that mean I need to stick to 44.1khz or 48khz, or does the ES-6 magically support higher sample rates when connected to the ES-8?
You would need to stick to 44.1 or 48kHz, if just using the ES-8/ES-6.
If you used an ES-3 as well, then you could run the ES-8 at 96kHz and the other two would work at 48kHz.
mdoudoroff
That’s what I figured. Thanks!
