a Diy S-Trig to V-Trig that works!
Author a Diy S-Trig to V-Trig that works!
nihilandvoid
Hello All!
Got my hands on a Roland Juno 6 and Korg KR-55 and discovered that the trigger output from the Korg was the opposite of the what the Juno 6 needs, so I set about looking for DIY solutions to convert the S-Trig to V-Trig.
few results came up and none of them had any confirmation they worked... I tried one from a page and nothing happened... damn!
After a bit more research I came across a page about the TR707 trigger output, and how the internal triggers in the 707 are actually S-Trig and the Rim Trigger output is converter to V-trig! It was a very simple circuit and I figured it would be perfect.
I drew up a schematic, incorporated a voltage divider to step a 9v battery down to approx 5v+ and vero boarded it.
YES! it works FANTASTIC!
So... i figured id share the schematic so future DIYer's can have a working solution to this problem.
I built mine into a small plastic box and used a stereo input jack so i can disconnect the 9v battery's Negative by unplugging the jack (much like a Pedal).
Here is the Schematic.
