Help with an Akai AX-60
Author Help with an Akai AX-60
nihilandvoid
Hello all
urgently need some help, I owned an Akai AX60 which worked great when i had it, but i sold it to a guy a few states away, and after its arrived its developed a constant high pitched oscillation.
Here is a link to a recording the guy sent me.
https://drive.google.com/file/d/1xs5i4_Te-4e3Pb_nQB7KTSeaYkhxDJUC/view  ?usp=sharing
You can hear the chorus modulating the oscillation so its definitely internal.
I packed it very well, but i can only assume it received a knock during shipping enough to maybe dislodge a connector or IC. How likely is it for something like that to cause this issue?
Its strange that it made no such noise when i used it.
Anyway, any help i can get to solve this will be a great help.
Alex
nihilandvoid
Please help! the guy wants to refund it now... if i can avoid this it would be a real help. He has found that if the chorus is off it doesnt make the noise, what in the chorus circuit could be causing that noise?
tIB
Is the buyer happy to open it up and check that all the internal connections are connected? I'd start there if fine when left...
nihilandvoid
He has done that and apparently everything looks ok, the only thing i can think of is that the bias calibration has gone off and the little trim pots need to be adjusted again.
