Piston Honda MKIII trouble saving startup preset
MUFF WIGGLER Forum Index -> The Harvestman
Author Piston Honda MKIII trouble saving startup preset
L.C.O.
I am having hard time setting Piston Honda MKIII up so that it powers up with a selected preset.
I believe that I am following the manual sequence, but it always seems to start up with preset manager off, and with the default sound.
I have set the STARTUP: the Preset ON
and
SAVE TO PRESET, my particular settings.
After power cycle, it seems to revert the Global settings to Preset OFF, and always starts with the same default sounds.
Someone please explain to me what is the right way to do this.
I read the manual section 3 times by now...
Is anyone able to do this successfully?
Thank you!
(I have emailed IME, and messaged them via Facebook, but have not heard back.)
mt3
What firmware are you running?
Restart the module and the firmware version displays for a few seconds.
The manual for the 1.1 firmware is here:
https://ime-assets.s3.amazonaws.com/uploads/manual/manual/24/phmk3manu al11.pdf
mt3
On firmware ver 1.1 it worked fine for me.
From the manual (under the GLOBAL OPTIONS menu, accessed via pressing the ENCODER and LINK simultaneously):
STARTUP:
This menu item allows you to enable the preset manager when the modular system is powered on. You may choose to leave PRESET OFF or select either PRESET or MORPH mode ON.
jwise
This firmware update to v1.2 was posted some hours ago: http://www.industrialmusicelectronics.com/products/21
mt3
https://ime-assets.s3.amazonaws.com/uploads/firmware/firmware/20/pisto nmk3fw12.zip
