New 4x Plugins for Gieskes 3TrinsRGB1
Moderators: luketeaford, Joe., lisa, Kent, daverj
videowerkstatt
Post by videowerkstatt » Wed Aug 08, 2018 8:40 am
Hi,
there are new plugins avalaible by Gieske himself for the 3TrinsRGB1 :
Ordered my kit today, can't tell more than that is on the web site:
http://gieskes.nl
http://gieskes.nl/instruments/files/3TrinsRGB1/Plugins/
All the best
hs
FetidEye
demonic space drone
Post by FetidEye » Wed Aug 08, 2018 9:28 am
thanks for the tip!
I think I will build the 2in neg video and the in-lines , the video's look sick!
sync24
Post by sync24 » Fri Aug 10, 2018 4:22 pm
ordered!
videowerkstatt
Post by videowerkstatt » Sat Aug 11, 2018 2:50 am
..received mine (on a saturday).. soldering iron is heating up..
moloque
Post by moloque » Sun Aug 12, 2018 3:15 am
ordered as well!
maggan
Post by maggan » Sun Aug 19, 2018 1:57 pm
Soldering these next week. :)
sync24
Post by sync24 » Mon Aug 20, 2018 5:14 am
arrived!
Lento_Zoom
Post by Lento_Zoom » Tue Aug 28, 2018 1:34 am
These add so much to the 3trins!
I managed to stack the 2xSPDT+4XSPST on top of the Video in-lines.
sync24
Post by sync24 » Tue Aug 28, 2018 10:10 am
Lento_Zoom wrote:These add so much to the 3trins!
woah! absolute MADNESS!!!
I LOVE the Video in-lines :love:
moloque
Post by moloque » Thu Aug 30, 2018 3:43 am
Really nice! Still gotta solder them... hopefully will get the needed time soon.
sync24
Post by sync24 » Thu Aug 30, 2018 6:12 am
hmmm, am finding Video In-Lines to be the easiest to get results from.
The others not so...
Anyone care to share any tips?
I have copied the patch from here (4s in) for video in-lines:
Lento_Zoom
Post by Lento_Zoom » Fri Aug 31, 2018 12:34 pm
sync24 wrote:hmmm, am finding Video In-Lines to be the easiest to get results from.
I might be able to help.
The SPST&SPDT is kind of like a CV controlled switch.
I have a better understand of the 1 side. So you take a signal, say video from the header and patch it to 1AB. Then run B- to 1Anc and R- to 1Bno. Finally, run one of the LFOs to 1CTRL. Start turning the knob on the left you should start seeing the video input jumping from B- to R- in time with the LFO. The know sets the point where the switch switches.
The B side is similar, but it just connects two points On or off, instead of the A sides 'this or that'.
2xSPDT&4XSPST is similar, but no voltage control. You can patch variations to the buttons and manually toggle between different modulation sources, color mixes, ect.
I've gotta play with 2x Video in negative more. It is pretty much two more video inputs, but no synchronization, so other inputs are likely to slide around.
Hope some of that helps!
FetidEye
demonic space drone
Post by FetidEye » Fri Aug 31, 2018 5:32 pm
no sync is free animation :)
sync24
Post by sync24 » Sat Sep 01, 2018 5:00 am
ah, great!
thanks, that makes sense to me now :)
I'll have go patching later and see how I get on.
Cheers!!!
sync24
Post by sync24 » Mon Sep 24, 2018 5:51 pm
had my 3trins set up with video lines plugged in at the weekend at Fort Process :)
you can see the Bradford Bahama beast in the foreground in the linked pic:
f4c3v4lu3
Post by f4c3v4lu3 » Mon Oct 15, 2018 11:57 am
Awesome! Been wanting to design something like this for a while - makes sense Gijs would beat me to it ;P
Return to “Video Synthesis”
