6MIX dead after resistor change?
Support and discussion for Antumbra modules and DIY builds
Moderators: Kent, antumbra
autodafe
Post by autodafe » Fri Aug 10, 2018 1:46 am
I have built a 6MIX
it was working, I only had something strange in the LEFT button which was always lit and didn't mute anything
I had places some "bigger" 470 Ohm resistors and I was supecting they were the issue (I had soldered them badly just to make contacts with the pads)
I had some 470 Ohm ferrites with the correct size and decided to replace the left resistor with one of these
As soon as I powered the module, no light from the buttons and from the LEDs...it seems dead
is it possible that the ferrites caused the burn? or maybe I shirted something?
what should I try to replace now?
flts
Post by flts » Fri Aug 10, 2018 2:26 am
As mentioned in viewtopic.php?p=2885508, the 470 ohms in case of a ferrite bead is not DC resistance like with a resistor, but a high frequency resistive impedance value.
So basically that change is almost the equivalent of shorting the 470 ohm resistor, which means it's highly possible there is some damage done.
autodafe
Post by autodafe » Fri Aug 10, 2018 3:32 am
ok thanks.
what might I have damaged now? I don't think there are schematics for the mixer....
synthetek
Post by synthetek » Fri Aug 10, 2018 9:41 pm
The 2 470R look like they are current limiting resistors for the LED in the switches so It could have blown those LEDs, but if nothing is working I would check the diodes by the power connector first. Also check the R3 and R4 the 10R resistors by the power connector.
http://antumbra.eu/content/bom/6mix/v1- ... matics.pdf
Return to “Antumbra”
