Horstronik Joystick not working in Make Noise Skiff
Author Horstronik Joystick not working in Make Noise Skiff
aokjoey0
Good, EDT Morning!
Here is my sad tale of woe.
I have a Horstronic Joystick that I had professionally built. I put it in my Sythrotek 7U case and it works great. When I put it in my Make Noise powered skiff, both LEDs go on and a fixed 7-8 volts are output on both the x and y outputs. Movement of the stick or knobs produce no changes save for a few millivolts. I took out all the modules in the MN skiff and still get the same problem.
I'm going to contact MN and Horstronic obviously, but I was wondering if anyone else had this problem or might know of any significant difference between the MN and Synthrotek buss systems that might explain this behavior.
TIA,Joe
