PISTON HONDA MK3 firmware 1.2 released
MUFF WIGGLER Forum Index -> The Harvestman
Author PISTON HONDA MK3 firmware 1.2 released
mt3
PISTON HONDA MK3 firmware ver 1.2 released:
https://ime-assets.s3.amazonaws.com/uploads/firmware/firmware/20/pisto nmk3fw12.zip
Bug Fixes
* A test condition escaped the test mode enclosure and sometimes led to ADC slowdown at startup. It has been eliminated.
New Feature: Startup preset mode changed
Under the "Startup" item in the global options menu, you may now select "Preset off", "Preset x", or "Morph x" where x is the preset number of 1-8. When the system is restarted, the module will boot into the specified mode with the preset number selected. Note that if your Preset Knob Mode is set to offset and the physical position of the preset attenuator knob is not zero (or if voltage is present on the Preset CV input), this will affect the selected preset number.
