LO-Fusion VCF by FEEDBACK [Build UPDATE]
strat-1
Post by strat-1 » Mon Aug 27, 2018 10:04 am
UPDATE : We uploaded all the files needed for the build of LO-Fusion
www.feedbackmodules.com
LO-FUSION is a remake of the classic Polyfusion from the 70s with some improvements.
It is a low pass OTA VCF based on the well known LM13700 ic.
We chose to make this circuit because it's v/oct stable, and the trimmers allow to calibrate it properly.
It has a switch for 2 pole and 4 pole configuration, each with it's own character and timbre.
This design produces nice sounding filter fm results.
For the audio demos we used two oscillators slightly detuned as the sound source.
Output with switch in 4Pole position.
https://soundcloud.com/strat1/lo-fusion-4pole
Output with switch in 2Pole position.
https://soundcloud.com/strat1/lo-fusion-2pole
VCO inserted in FREQ CV input.
https://soundcloud.com/strat1/lo-fusion-fm-modulation
LPfet through VCA. ADSR to VCA and another ADSR for LPfet.
https://soundcloud.com/strat1/lo-fusion-adsr-modulation
There are 2 type of kits available :
KIT1 : 20EUR (2PCBs+FrontPanel)
KIT2 : 35EUR (Pcbs+FP, 4x2N5457, 5xminijacks, 1x50KA POT, 3X50KB POTS, 2xboard connectors, 4xCream Knobs)
COMPLETE MODULE : 90eur
KIT1 :
KIT2 :
Swyndger
Post by Swyndger » Mon Aug 27, 2018 1:29 pm
Sounds good ... Thank you, Strat!
Kit2 is ordered as soon as I can order it ;)
(And next feedback-module you create is the Sum-Module for your Preamps, yes? ;) )
strat-1
Post by strat-1 » Mon Aug 27, 2018 1:35 pm
Swyndger wrote:Sounds good ... Thank you, Strat!
OK, I will start to work on the SUM module :)
secrethero303
Post by secrethero303 » Mon Aug 27, 2018 3:31 pm
Sounding good. Looks like you have been quite busy with all the new modules coming our way. Looking forward to making some orders when they're released.
Swyndger
Post by Swyndger » Sat Dec 22, 2018 8:32 am
Hey Strat!
I have some issues with this Filter, as I have with the HI-Fusion.
Both of them do absolutely nothing.
I've build both following the values on the PCB, searched for mistakes, replaced C1 printed on PCB as 47uF with a 100uF from the schematic, checked the voltage of every IC, resolderd almost everything and replaced most of the ICs. Still both filter stay quiet.
Now I started to follow the signal path, and I can measure it on U1A output (pin 6) but not on conector 2-2.
EDIT: Sorry, it seems, that I used the schematic of the HI-Fusion for the LO-Fusion, but still there is a signal un the U1A output, but no signal after R6, so I have to recheck everything again ... forget the rest of the post!
(((( So this is nonsens: On the schematic U1A pin 6 is directly connected to CON2 pin 2-2, but in the PCB I cann follow the path to R3 and R6(!?!, 20k printed on PCB, 100k in the schematic), and R6 goes to CON2 2-2. But following the schamatic R6 should belong to the Frequency CV input. I am puzzled! )))
Thank your for your help, and thank you for your great modules, I've build all of them, and except these filters (and the multi-dimension, but that is another thread) all of them work wonderfull :)
strat-1
Post by strat-1 » Sun Dec 23, 2018 3:48 am
Swyndger wrote:Hey Strat!
I will do my best to write the manuals in the next days.
I was busy in developing two new projects and keep the pace with the orders in the same time.
strat-1
Post by strat-1 » Mon Dec 31, 2018 1:13 pm
UPDATE : We uploaded all the files needed for the build of LO-Fusion VCF
strat-1
Post by strat-1 » Mon Dec 31, 2018 1:58 pm
Swyndger wrote: I've build both following the values on the PCB, searched for mistakes, replaced C1 printed on PCB as 47uF with a 100uF from the schematic, checked the voltage of every IC, resolderd almost everything and replaced most of the ICs. Still both filter stay quiet.
The changes I made in the manual :
-47u input cap to 100u cap. This will allow to pass more lows into the filter.
-R2 should remain empty. This resistor is to lower the input level.
-C10, C11 are changed from 220nf to 1uf.
-Changed R9 from 300Kto 240K for a better FREQ pot range
Swyndger wrote: Now I started to follow the signal path, and I can measure it on U1A output (pin 6) but not on conector 2-2.
Try the calibration procedure from the manual.
Also. see if the pages with board layers from the end of the manual can help you.
I've built a lot of filters using the manual and they are all working.
strat-1
Post by strat-1 » Tue Jan 01, 2019 6:23 am
Swyndger wrote:(((( So this is nonsens: On the schematic U1A pin 6 is directly connected to CON2 pin 2-2, but in the PCB I cann follow the path to R3 and R6(!?!, 20k printed on PCB, 100k in the schematic), and R6 goes to CON2 2-2. But following the schamatic R6 should belong to the Frequency CV input. I am puzzled! )))
I forgot to ask. Did you used 2n5457 fets ? J112 are not working in this design.
Swyndger
Post by Swyndger » Mon Jan 14, 2019 2:52 pm
Sorry for answering so late. I hadn't much time for SDIY recently.
Yes, I used 2n5457.
I removed R2, but did not do the other changes right now.
Calibratiom is not possible, except of the DC offset for the input as I have no output signal.
Still the main issue is the following:
I have the signal from the input (VCO) on output of U1A, a pulse with 6Vpp for example.
But after R6 (20kOhm) and so CON2 PIN2-2 the signal is gone.
Even if I bridge R6 something puls down the signal to Zero.
If I open the conection CON2 PIN2-2 the signal is on the CTRL-Board, so the issue should be un the main board.
Removing the LM13700, still no Signal.
Measuring resistance between GND and CON2 PIN2-2 I get something about 66 Ohm. As R26 ist just 100 Ohm, this should be OK. So no short.
But something pulls the signal down as soon as it reaches the main board.
And as the HI-fusion has the same issue, it isn't just a bad soldering.
So I had no time to search further, maybe in a week or so ...
... Could the 2n5457 be the problem. The eight I used for HI- and LO-fusion where the last I had. Maybe I got a bad batch. Or the 2n3906? I matched them, but who knows?
strat-1
Post by strat-1 » Mon Jan 21, 2019 6:07 am
I just finished to build a couple of LO-Fusion VCFs for selling as built modules, so I used the opportunity to make some measurements and do a troubleshoot file.
I hope this helps you, and others in finishing the module.
So :
Turn FREQ on max (CW) and RESO at min (CCW)
Feed a 8vpp or 10vpp saw on input, and adjust ATT pot util you have an 8vpp saw on point 1.
You should have approx the same reading on point 2. The first op-amp works as non-inverting amplifier.
If something is wrong in this step, check U1 (UA741) for defects, shorts etc.
You should have approx the same reading on point 3, but inverted. Each LM13700 op-amp works as an inverting amplifier.
If something is wrong in this step, check u6 (LM13700).
You should have approx the same reading on point 4. Each 2N5457 work as a buffer.
If something is wrong in this step, definitely the 2N fets are not working.
Do the same for each LM13700 stage 5,6, because they work as inverters, you should have inverted waveform.
You can't have a reading on point X, because on inverting op-amp circuits, the negative input goes to 0V.
Check if U4 is working by taking a reading in point 7.
Now is time to check the freq control circuit.
By turning the FREQ pot from min to max, check if you -3.6Vdc to +600mvdc on point 8.
By turning the FREQ pot from min to max, check if you -9.8Vdc to -9.2vdc on point 9.
The LM13700 OTAs are controlled in current, but having this slight dc variation on point 9, shows you the transistor circuit is working.
Swyndger
Post by Swyndger » Sat Jan 26, 2019 4:37 pm
Hello Strat! Thank you, very, very much!
Following your troubleshoot instructions:
I checked the singal on TP1 and 2 and it was good.
But no signal on TP3.
Changed the LM13700 to some of another batch, but no difference.
Checked (again) the voltage of U6, and (again) the values of the resistors arround U6 etc. but everything is fine. Had allready replaced the FET.
So I was just about to give up.
But then I thought I could check the frequence control as described, too.
And I had -10,3V on TP8 the whole time. Nothing changed while turning the FreqPot.
Replaced U2, but no difference.
Output of U2A seemed to be Ok, cand remember the exact voltage, but it changed while turning the FreqPot.
So I checked (again) all the values of the components around U2/Frequency Control ...
... and I saw what stupid :bang: mistake :bang: I have made: R14 was 51k (like R15) and it should be 5k1! So the whole filter was shut the whole time, and so I never could hear or measure anything.
Replaced R14 with the right one, and the filter works. :nana:
Tomorrow I will replace it in the HI-Fusion, too - as I've build both togerther, I made the same mistake twice :oops: -, make the changes you have made in the build manual, calibrate them and then I will have two new filters.
Once again: Thank you, Strat!
vibralux
Post by vibralux » Tue Feb 12, 2019 11:51 am
God damn it. I just received my Lo/Hi Fusion and Fet Filters and these sound sooo different than anything else I have. And I have plenty: Belgrad, Dual Borg, Korgasmatron, Filter 8, Wasp, RK6. This is truly unique. :woah:
MY YT CHANNEL WITH MODULES REVIEWS:
https://www.youtube.com/channel/UC3IgU2 ... hKH8ou7YTQ
MODULARS, ABLETON, MIXING. Stop reading manuals. Start making music.
http://www.colormysound.com/
humax5600
Re: LO-Fusion VCF by FEEDBACK [Build UPDATE]
Post by humax5600 » Sun Jan 12, 2020 12:51 pm
Finished today.
Works perfectly and sounds fantastic !
:yay: :hihi:
