Plumbutter 2- Snare and Mixer
home of post-70s electronics
Moderators: Kent, bartlebooth
merlatte
Post by merlatte » Sat Sep 01, 2018 8:03 pm
Hi. So I got a Plumbutter this week and it’s been crazy fun to learn. The only issue I seem to be having is that Mixer doesn’t seem to be able to mute the snare drum completely- it’s soft at full CCW but definitely still there. All of the other sections are silent at full CCW. Is this normal?
knows
Post by knows » Sun Sep 02, 2018 7:12 pm
It seems to be normal, but annoying.
merlatte
Post by merlatte » Sun Sep 02, 2018 11:05 pm
That's a bummer. I shot Peter an email and will update if this isn't a normalcy.
Hainbach
Post by Hainbach » Mon Sep 03, 2018 12:47 am
Its normal. I simply unplug, so easy with bananas.
knows
Post by knows » Mon Sep 03, 2018 1:39 pm
I bit of noise/bleed from the snare is worth it when using the dust to trigger the man with red steam.
qwoned
Post by qwoned » Wed Sep 18, 2019 8:35 pm
the snare on my pb2 suddenly becomes very quiet, near inaudible, while in use. mixer level is fully cw. not sure why, doesn’t matter what I have patched into the green jack. seems to get quieter throughout use. should I bother Blasser with this? any advice on what might be causing the drastic signal drop would be very much appreciated. I’m using 9V battery for power.
jimmie
Post by jimmie » Thu Sep 19, 2019 8:17 am
9v battery can't drive the snare enough, all other parts are fine with it, tho (as far as i know).
qwoned
Post by qwoned » Thu Sep 19, 2019 2:51 pm
yes, this seems to be the issue. thank you!
ideaofnorth
Re: Plumbutter 2- Snare and Mixer
Post by ideaofnorth » Wed Jun 24, 2020 8:06 am
Brand new PB2 owner here and glad I found this thread. I have a power supply on the way but I had a nice patch I was happy with when suddenly the snare became nonexistent. Glad to know it's a battery issue, thanks!
Return to “Ciat-Lonbarde”
