delay AND reverb pedal
MUFF WIGGLER Forum Index -> Guitars, Basses, Amps & FX Goto page Previous  1, 2 [all]
Author delay AND reverb pedal
kragg
Thank you for your advice, Grep.
Rex Coil 7
Line 6 M13
.... I have two of them, my wife has one, and my live-in disabled younger brother has one of them. So we have four M13s in our combined home studios.
TALENTS:
*** Four FX "blocks", each with something like 130+ FX models to choose from.
*** Sets of twelve FX models of your choosing arranged in "Scenes". You may name your Scenes using any names you wish.
*** 48 Scene memory (that comes to 576 FX model user presets).
*** Auto-Save function ... it automatically saves all of your FX settings without having to do anything ... just set up your FX sounds, and your work is auto-saved. This function may be changed so you must manually "push this, pull that" to save your settings.
*** You may set the signal flow to go from left to right, or right to left.
*** Ability to split the four FX blocks into two separate completely independent ~chunks~ using the full on stereo send/return jacks.
*** The Send/Return "split" may be placed in the signal chain at any point between the four FX blocks (between 1-3 ... 2-2 ... 3-1).
*** Ability to use TWO expression pedals (totally assignable to each of the four FX blocks and assignable to any/all of the five controls per FX block ... some functions can be increasing while others are decreasing as you go from heel to toe).
*** Full stereo In/Out, full-on MIDI I/O (5 pin DIN at that!).
*** The 24/48 second phrase looper makes the M13 highly unique. When recording a loop, the phrase looper may be placed either before the FX or after the FX when capturing a phrase ... you can capture a phrase with any/all of the FX applied to it ... and then the phrase may then be played back before the 4 FX blocks so you may apply even more FX to the captured loop.
*** The loop can be played back in reverse (foot-switchable) and placed before the FX so you can apply the FX to a reversed loop.
*** The loop can be played back at half speed (foot-switchable) and placed before the FX so you can apply the FX to the half speed loop.
*** You can use expression pedals (up to 2 of them) to tweek the FX that any of these loops are being recorded with, and/or played back through.
*** I took things a bit farther by building a simple/inexpensive joystick, I plug the X axis into one expression pedal input, and the Y axis into the other expression pedal input. The M13 doesn't know an expression pedal from a B10K pot ... so you may use pots (knobs), or a joystick, or expression pedals plugged into the "expression" input jacks.
You already know what is packed inside the M13 (sounds/fx) since you have an M5.
I've been able to buy the M13 for as little as $225.00 shipped (used) in excellent condition on eBay. Just be patient and persistent.
What else can you buy for $225.00 shipped that provides all of that function and sound?
Mr. Green
kragg
Yes smile
And one neat thing i like about the M5 is that you can map several parameters to the single expression pedal, each one with a different range SlayerBadger!
Like you mentioned, I built a simple "one knob box" that i can put on top of an electric piano, and it can change both the mix, decay time and and tone at once.
The M13 seems a bit too big for my live rig (i have a Zoom G3, which has a nice form factor, but is a bit weak when it comes to delays and reverbs).
kragg
I just discovered this one today :
https://collisiongears.com/
https://www.facebook.com/collisiondevices/
xenosapien
@the BOSS RE-20:
I have one and recently used it as my sole send/return FX for a small improvised live set with a modular...
from that I can confirm: great characterful sounds, "vintage" in a box that requires no tape changes or maintenance
BUT:
if you need clearly audible repeats, you´ll have to dial that in VERY carefully and probably not use the reverb part.
it gets muddy/cloudy really fast, not in a bad way - but very definitely not able to get that clean sound most of the other boxes mentioned here provide.
Addam
Any lucky ducks get to play one of these from the first run? Second run supposedly coming soon. Looks like 229 USD
smetak
From Old Blood Noise, got their second version of the Dark Star - man, that bitcrusher mode is out of this world! - and their new Flat Light where you can get some really great modulation.
chinard
Another vote for the Mooer Ocean Machine
It has become my go-to box for almost everything lately and has plenty of knobs going on.
Effectively if you are just looking at it from the front panel point of view, both delays and reverb can be used without any menu diving, and with 'trails' enabled you can change reverb and delay modes while playing.
Each effect gets a dedicated mode knob and 4 dedicated parameter knobs. very easy to use without getting sucked into preset hell
You can also change the chaining pattern on the fly as well which is super interesting. Especially handy with the built in looper being able to insert it anywhere in the chain.
The looper is pretty damn basic and unfortunately has no undo, but it does support 1/2 speed and reverse.
There is an optional 'wireless' foot controller for it, but i found it to be more or less useless, and they did not think far enough ahead to allow you to remap the switch function.
What works better instead i find is a SourceAudio Soleman MIDI foot controller. With this you can really expand what the ocean machine can do, plus have the pedal at desktop height for knob tweaking while controlling with your feet.
Some of the extra things i have mine configured for are: Freeze effect for reverb/delay1/delay2, reverb shimmer control, extended looper control, and i can also use an expression pedal to control the input vol like a morley pedal.
wvrm
Doesn't tick all your boxes, but the Boss RV-3 is damn good and can be had quite cheaply.
Struggle
Just scored a Specular Tempus from a friend and I’m in love. Really just wanted it for the lush verbs, but I’m pretty stoked with the delays so far too. Easier to navigate than I had expected.
kragg
Thank you all for the tips !
Zube
Friends of friends of made this. Great players and nice people. Haven't had a chance to try myself, but it is a new favorite of those i trust who have one.
Addam
Zube
Very cool. I just ordered an OBNE dweller, which is the first guitar pedal I’ve bought in a couple years. If I can sell some stuff I’d like to grab the Rever too.
a100user
Just a wild offering but Nick @ Sonic State uses one of these on his demos and I really like the sound - more reverb than delay but does cover delay ground too.
https://www.sourceaudio.net/ventris-dual-reverb.html
Page 2 of 2
