stereo panning on the cocoquantus
home of post-70s electronics
Moderators: Kent, bartlebooth
odditymedium
Post by odditymedium » Tue Sep 11, 2018 4:08 am
can i mix the stereo pan without an external mixer?
i.e right now its hard panned, but anyway to mix em?
Oldstench
Post by Oldstench » Tue Sep 11, 2018 8:19 am
Nope. Welcome to Ciat-Lonbarde.
Humanity has doomed itself.
chrisdermo
Post by chrisdermo » Tue Sep 11, 2018 8:34 am
You can get stereo -> mono plug converters. But then you're left with something that will only play in one headphone if thats the way you're using it.
WTB / WTTF: Bugbrand PRC2B, DD3, PRC4, ENV1
Current Bugs frame:
https://www.modulargrid.net/f/racks/view/580413
odditymedium
Post by odditymedium » Tue Sep 11, 2018 10:04 am
Oldstench wrote:Nope. Welcome to Ciat-Lonbarde.
thanks. but why does peter do this? whats the reasoning
Oldstench
Post by Oldstench » Tue Sep 11, 2018 12:24 pm
Don't know. He's a quirky fellow, I'd gather.
CL gear is unlike anything else. There's good and bad in that, for certain values of bad. Hard panned left and right channels is one of those values for some. The PB2 (maybe the OG PB as well? Don't know - never had one) does the same for the Gongues, AVDogs, and Deerhorn. Hard left, hard right.
Run it into a DAW or get a small mixer.
kozepz
Post by kozepz » Tue Sep 11, 2018 12:44 pm
Both the original cocoquantus and plumbutter uses 2 mono outputs.
elil
Post by elil » Tue Sep 11, 2018 2:30 pm
You could route the right channel into the left and the left into the right and attenuate to taste.
odditymedium
Post by odditymedium » Tue Sep 11, 2018 4:12 pm
yeah thats what i'm doing now, but it feels wrong :-|
how do you turn it off? just unplug it? feels like a violation
Oldstench
Post by Oldstench » Tue Sep 11, 2018 4:22 pm
odditymedium wrote:yeah thats what i'm doing now, but it feels wrong :-|
Just unplug it.
mrbloor
Post by mrbloor » Tue Sep 11, 2018 5:25 pm
I use a stereo mini jack to mono jack summed cable on my Sidrax & Tetrax if that helps anyone. cable from babylon
Hainbach
Post by Hainbach » Fri Sep 14, 2018 1:29 am
Have you started to modulate the VCA? The resulting movement should explain why the stereo spread on Ciat-Lonbarde is part of its acoustic body.
papercutnoise
Post by papercutnoise » Sun Sep 16, 2018 4:50 pm
Hainbach wrote:Have you started to modulate the VCA? The resulting movement should explain why the stereo spread on Ciat-Lonbarde is part of its acoustic body.
Had great fun earlier today running a Sidrax loop (recorded in to a Line 6 DL4) into the Cocoquantus and having various Quantussy outputs modulating the input and output VCAs. Repatching and playing with the chaos on the Quantussy brought out some hypnotic rhythmic variations. Definitely something I want to explore more!
Good Transactions with: Pfurmel, Parallel Worlds (x2), Miditerranean, Ping Panic (x2), Soy Sos, jenamu6, READYdot, Poladark, Synesthesia, audioCTRL, dansna, Glitchmachines, RealDudes, wavecircle, msh
drwiener
Post by drwiener » Sun Nov 11, 2018 7:24 pm
... when you plug another ciat instrument into it, it's stereo field is preserved.
for example the tetrax, sidrax, and deerhorn, all create amazing spatial pallets when performed.
Or if you plugged your PB into the coco, then you would have some instruments going to one delay and some to the other -- hence two delay settings for your drum machine.
I think the idea is that you will patch the instruments into eachother, and the panning/ seperation is preserved.... IE the inputs on the plumb split to both filters, and the inputs to the deerhorns do the same with the VCAs.
Return to “Ciat-Lonbarde”
