USAMO and Linux?
Author USAMO and Linux?
AppAraat
Hi,
I use Bitwig on Linux and I was wondering if it was possible to use the USAMO plugin (preferably natively)
Thanks.
tom moody
The USAMO software doesn't have a Linux version -- see http://www.expert-sleepers.co.uk/downloads.html
There may be third party efforts to get ES software to work as a Linux plugin using Carla and/or Wine but I don't know how successful they have been.
AppAraat
Yeah that's unfortunate, I thought perhaps ES had plans for it. Is the protocol spec otherwise documented somewhere? If so, then I could try to hack a plugin together that sends out the necessary audio stream to the USAMO.
tom moody
This thread may or may not be helpful:
https://www.muffwiggler.com/forum/viewtopic.php?t=114022
From what I've read ES has no plans to make Linux versions. It's encouraging to see Bitwig and Tracktion becoming more Linux-friendly, and some ES hardware is usable for those DAWs.
AppAraat
Thanks for linking me that! However, the github link in that thread doesn't contain externals for ESX-8MD, only for ESX-8CV. Which is certainly strange, since the ESX-8MD page mentions a Max/MSP external, but the downloads page does not mention the ESX-8MD (under Max/MSP externals).
Otherwise I could purchase the ES-40 and the ESX-8MD, which is much better in my case than getting multiple USAMOs.
Perhaps os can shed some light on this situation?
The page says
The ESX-8MD requires software in order to operate, as noted above. Currently, the only such software is Expert Sleepers Silent Way, and our Max/MSP external. Note that MIDI functionality is only available via Silent Way.
The external lets you drive the outputs of the ESX-8MD, from which you could construct e.g. a DINsync clock. It doesn't do the MIDI stuff though.
